4Age Diagnostic Error Codes
#1
Posted 30 October 2010 - 10:55 PM
sorry in advance for the rookie question i just having such a hard time tracking down that list again.
#2
Posted 30 October 2010 - 11:12 PM
5 - o2 sensor but was only listed on the late code database.
9 - Vehicle speed sensor signal Signal from the vehicle speed sensor is 0km/h for several seconds when the engine speed is faster then 2,800rpm and the intake manifold pressure signal is over rated value.
10 - Starter signal STA signal was not received until the engine exceeded 800rpm at vehicle speed 0km/h
I take it your speedo is not working?
Pull the "STOP" light fuse out of the drivers side kick panel to reset the fault codes, refit the fuse and check for codes, take it for a drive and recheck.
#3
Posted 31 October 2010 - 12:07 AM
#4
Posted 31 October 2010 - 03:31 PM
car cut out on the way out last night of all times! never would of thought my trusty rolla would cock block me
#5
Posted 31 October 2010 - 08:48 PM
how can I test the pump to see if it's broken and how likely is it for a fuel pump to just die all of the sudden?
my immobilizer does switch off the pump too but i'm not sure if it's the immobilizer's problem because i was driving when it cut out. suggestions on how to test the pump would be great.
#6
Posted 31 October 2010 - 09:25 PM
How do you know that the immobiliser is working and does the engine light come one when you turn the key on?
To manually run the fuel pump you need to turn the ignition to "ON" and bridge the terminals of the T looking plug next to the diagnostic port (passenger side firewall under wiper motor), the pump should sound.
If you are unsure what the plug looks like, here is one for reference but dark blue instead.
T 2pin Plug
#7
Posted 01 November 2010 - 12:24 AM
Just giving a heads up too, this is a ke70 with a conversion, was running sweet before i went away over east and was running for a while just randomly cut out last night.
I'll test the pump like you suggested with shorting the terminal and see if it's working or not.
#8
Posted 01 November 2010 - 05:30 PM
ok.
Well it could be anything, if you don't know the conversion then it is sometimes a pain in the ass to work out where to start, this also explains why you have to speed sensor.
The pump is probably hooked up to an external source and not the ecu so it might not work.
#9
Posted 01 November 2010 - 08:57 PM
tomorrows job: look for bad wire connections and bad earth points.
#10
Posted 01 November 2010 - 09:14 PM
In my previous post I meant to say "no" speed sensor and not to.
#11
Posted 02 November 2010 - 01:12 AM
Think there is just a weak connection somewhere, because today we started the car by engaging the relay by hand and when you let go of the switch the electro magnet kept the switch engaged when the engine ran and disengaged as it should.
I'm thinking I have one of a few problems going on:
1. there is a bad earth somewhere and the circuit isn't getting good continuity
2. my battery might be on the brink and can't power the relay enough to engage when cranking.
3. loose connections somewhere.
4. relay is just getting old.
#12
Posted 02 November 2010 - 10:58 AM
http://www.rollaclub...ng_Relay_Wiring
but i used that to wire up mine.
sounds to me like you havent got the start signal hooked up correctly?
also, at home i have a pdf on how to make a circuit opening relay out of 2 standard relays. so if you want i can send that you way if your COR is just stuffed.
Edited by ke70dave, 02 November 2010 - 10:59 AM.
#13
Posted 02 November 2010 - 04:44 PM
from what it looks like looking at that COR plug the previous dude wired up the earth and the starter signal up in reverse. (white/black was earthed and black connected to starter signal).
will try swapping them over and see how it goes then.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
