4K- 4Age Distributor How To.
  • Please log in to reply
14 replies to this topic
#1 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Online:08 Jan 2015 10:20 PM
  • Gender:Male
Posted 14 December 2011 - 08:23 PM
Hey there.
I've been trying to build my own custom electronic ignition, but it's not working out how I'd planned.
I want to get her running for the GOR.
So, I'm after a How - To 4k to 4age on carby distributor setup.
I have the parts, just need to know exactly what the set up is.
I need to know how the distributor is put together.
I remember seeing it somewhere when I first started the build but can't seem to find it again.
Any help is appreciated. Thanks guys.
EDIT: for clarification.
Edited by bAKER, 14 December 2011 - 08:27 PM.
#2 Trev
Trev
    Hachi Ni
  • Donor
  • 6716 posts
  • Online:Yesterday, 01:50 PM
  • Gender:Male
  • Real Name:Trev
  • CC BY-SA (recommended)
Posted 20 December 2011 - 12:47 AM
All I have from using a 4ac dizzy in my 4age:
http://www.rollaclub...post__p__248531
Seriously tho, you should run the 4age dizzy and use a BIM to control it for now (won't have advance) and then get a dizzy controller like a hyperpak once you have done the cruise.
If you scroll down you will see the BIM install.
Edited by Trev, 20 December 2011 - 12:49 AM.
#3 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 20 December 2011 - 06:33 PM
Thanks for looking.
I had a setup very much the same, lots of the no advance symptoms etc.
And my current attempt is with a DIY silicon chip, which was a very bad mistake. Impossible to run correctly.
I've tried for quite a while to get it working correctly, was almost there and then another problem came up and the situation started snowballing, so I'm fed up with that idea.
I'd like to get a hyperpack, but I can't source one. If I had one I'd have it running tomorrow.
Any ideas on where to find one?
Thanks again.
#4 Trev
Trev
    Hachi Ni
  • Donor
  • 6716 posts
  • Gender:Male
  • Real Name:Trev
Posted 20 December 2011 - 06:37 PM
 bAKER, on 20 December 2011 - 06:33 PM, said:
Thanks for looking.
Thanks again.
This is how he did it when I got mine:
Email the bloke at hyperpak (http://www.erd.co.nz...cts/toyota.html) he will then put one on eBay so you can purchase it.
#5 SLO-030
SLO-030
    RH Engineering.
  • Senior Member
  • 4499 posts
  • Online:30 Aug 2015 02:45 PM
  • Gender:Male
  • Real Name:Maurice
Posted 20 December 2011 - 06:46 PM
I looked into fitting the 4age dizzy into a K block a short time ago.
To fit 4K dizzy. Will need a bush for the dizzy to slide into. K dizzy diameter as the I.D and A dizzy diameter as the O.D. (will put up the sizes in a second).
EDIT:
Quote
The K dizzy has a 26.92mm body, While the 4AGE has a 36.02 body.
You need to remove the dizzy drive gear from both distributors.
Fit the A dizzy drive gear to the K dizzy shaft. Then trim shaft to the right length.
The body of the distributors (from where they sit against the block/head) to the end (where the hardened washer and gear sit against) are the same length.
The 4a dizzy's body drops down in size right at the end. You may have to grind/machine the K dizzy the same. Not sure if it was done for clearance of the cam in the 4AGE or for production costs.
Edited by SLO-030, 20 December 2011 - 06:50 PM.
Posted Image
Air goes in....Happiness comes out!
#6 SLO-030
SLO-030
    RH Engineering.
  • Senior Member
  • 4499 posts
  • Gender:Male
  • Real Name:Maurice
Posted 20 December 2011 - 06:54 PM
The go would be to make a brass bush with something like a 36.1mm OD and 27mm ID. Loctite into 4AGE head.
Slip 4K dizzy in. I'm also pretty sure the 4K dizzy clamp works perfect with 1 hole already in the GE head.
Posted Image
#7 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 20 December 2011 - 08:05 PM
Thanks Trev, I'll email him now.
I'm not too good at machining things, I'm more of a "use a hammer" kinda guy haha.
but this is what you mean yes?
Posted Image
I remember seeing someone make a spacer the thickness of the difference of the 2 dizzy shafts, instead of cutting the shaft? Which would save machining anything.
I'm not sure if I remember that correctly... Having said that, I've seen about 5 different ways of building it.
If I don't have any luck with the hyperpack, which seems like the more viable option at this stage. I'll use it instead.
Cheers.
#8 SLO-030
SLO-030
    RH Engineering.
  • Senior Member
  • 4499 posts
  • Gender:Male
  • Real Name:Maurice
Posted 20 December 2011 - 08:18 PM
Go to a local machinist. ask em to make you a brass or steel bush to the dimensions above. Then all you have to do is swap gears and cut the tab off the end that spins a K oil pump.
Bush like this
Edited by SLO-030, 20 December 2011 - 08:50 PM.
Posted Image
#9 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 20 December 2011 - 08:54 PM
ahh that makes sense ;]
#10 Trev
Trev
    Hachi Ni
  • Donor
  • 6716 posts
  • Gender:Male
  • Real Name:Trev
Posted 20 December 2011 - 08:56 PM
So you wanna revert to a points ignition on the 4ag or have you got an electronic dizzy for it?
#11 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 21 December 2011 - 07:07 PM
I'm weighing up my options at this stage. I'd rather electronic, and if I can't get the parts I'll fall back on the 4k dizzy.
EDIT:
Hyperpack bloke sent me an email, gonna buy one.
Edited by bAKER, 21 December 2011 - 07:34 PM.
#12 Trev
Trev
    Hachi Ni
  • Donor
  • 6716 posts
  • Gender:Male
  • Real Name:Trev
Posted 21 December 2011 - 09:53 PM
EDIT:
I would rather put a BMI onto the standard dizzy and have no advance then have to buy an electronic dizzy from a K motor and get a few bits made up for it.
Was the hyperpak $320?
#13 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 22 December 2011 - 06:14 AM
You don't think they're reliable?
$260, christmas special or some such.
Edited by bAKER, 22 December 2011 - 06:14 AM.
#14 Trev
Trev
    Hachi Ni
  • Donor
  • 6716 posts
  • Gender:Male
  • Real Name:Trev
Posted 22 December 2011 - 10:27 AM
No I meant no point wasting money when you can get the standard on to work for around $20 and advance is only there for economy.
#15 bAKER
bAKER
    POWWAAHH
  • Regular Member
  • PipPipPipPipPip
  • 435 posts
  • Gender:Male
Posted 22 December 2011 - 11:15 PM
Yea I suppose....
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
