K Series Head Identification Help Needed
Head ID Number 39
  • Please log in to reply
7 replies to this topic
#1 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Online:Yesterday, 10:11 PM
  • Gender:Male
Posted 07 August 2016 - 09:42 PM
Anyone know what engine, a K series head with ID number 39 (in casting between spark plugs 3 & 4), was fitted to ? No 39 is not listed in the Wiki. It is currently fitted to a 4K engine, I was looking at this afternoon, which has a few issues, one of which appears to be very high compression (about 180 - 190 PSI per cylinder). I'm suspecting it might be a 3K head on a 4K block. The engine runs on badly & is "dieseling". The engine is also fitted with a 3K dizzy. It has what looks like a carby without a fuel cut-off solenoid, so I suspect it might also be off a 3K.
Don't know the history of the engine mods, so it's a bit hard to make a call, without stripping it down & working through all of it.
Thanks !
Cheers Banjo
Edited by Banjo, 08 August 2016 - 06:45 AM.
Keep them olde COROLLAs rollin !
#2 gtnickk
gtnickk
    Long Live the Ke70 & Ke30
  • Regular Member
  • PipPipPipPip
  • 235 posts
  • Online:Yesterday, 12:41 PM
  • Gender:Male
  • Real Name:Nick
Posted 08 August 2016 - 04:16 PM
I had a 3k with that head casting, i found a thread somewhere indicating that it was from a 3kh which means high compression, but it think this only apply's to the block. I hope this helps. Also does it have a Welch plug at the back it could be an early Big port.
I hope this helps
#3 Seeno
Seeno
    New Member
  • Members
  • PipPip
  • 17 posts
  • Online:02 Sep 2016 07:46 PM
  • Real Name:Sean
Posted 15 August 2016 - 11:13 PM
i have a 75 ke30 with a 3k-h motor all matching numbers and the number i have stamped in the spot you said is 19 not 39 not sure if this helps but thought i post it up anyways
#4 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Gender:Male
Posted 16 August 2016 - 09:56 AM
Thanks Sean ! All helps. I note that 3K head ID no 19, does appear in the Wiki, but not 39. It definitely is 39; it is not a "typo". We might have to whip the head off & take a look see.
Cheers Banjo
#5 CorollaNut68
CorollaNut68
    Crash Magnet
  • Regular Member
  • PipPipPipPip
  • 227 posts
  • Online:28 Dec 2016 07:52 AM
  • Gender:Male
  • Real Name:Mark
Posted 28 December 2016 - 07:26 AM
Well????
What happened with the mysterious head #39????
This is as bad as Game of Thrones...start reading a story line...get interested in it....and it just stops!
Plus...this made me look at mine #24010-200, and according to the wiki it's a 3K big port "without" water jackets. What does that mean? It DOES have water circulating through it.
Edited by CorollaNut68, 28 December 2016 - 07:34 AM.
1968 KE10 Corolla 1100. Unknown miles when I bought it but I've added
759,008.4 miles 1,221,508.5 kilometers....so far
"I'll just drive this til I find something better" I said ...28 years ago....
#6 Taz_Rx
Taz_Rx
    Brappn or boostn
  • Tech Moderator
  • 6578 posts
  • Gender:Male
  • Real Name:Si
Posted 28 December 2016 - 07:40 PM
Water outlet in the manifold mounting face for water cooled inlet manifold.
I am just a worthless liar, I am just an imbecile. I will only complicate you, trust in me and fall aswell.
TAR - KE55E 5KTE. BB T28, 7K EFI, T50...all the good stuff!! :)
DIRT - KE55E 3/4kc. 4k w/- 3kBP head, 609 lumpstick, weber, extractors & exhaust etc....all the left overs!! :P
Un-named RX4 - 13bbp, weber, 2x2.5 ex, lensos....too much more to list!! :?
Posted ImagePosted ImagePosted Image
#7 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Gender:Male
Posted 29 December 2016 - 08:05 PM
Never did get a chance to get the head off this car & CC it, as the Rollaclub member young lady who owns this "moded" 4K in a KE20, uses the car as a daily drive to work, and can't really afford to have it off the road.
She has advised that she has recently had a weber & electronic dizzy fitted. She is bringing it around soon, so I'll get to see what the result was. Sometimes, a too high compression ratio, can work against you, and you don't get the result you expect. I expect that is what happened in this case.
Cheers Banjo
Edited by Banjo, 29 December 2016 - 08:05 PM.
#8 Clapped out
Clapped out
    Wannabe Ke Salvage
  • Donor
  • 1063 posts
  • Online:Today, 09:37 AM
  • Gender:Male
  • Real Name:Rural bogan
Posted 03 January 2017 - 06:50 PM
Cheers Banjo
Yes, yes it does!
Posted Image
I am a financial supporter of Rollaclub. You can be too.
Donate Here and support your forum.
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
