Head Bolts For 5K
  • Please log in to reply
10 replies to this topic
#1 rke_011
rke_011
  • Regular Member
  • PipPipPipPipPip
  • 269 posts
  • Online:13 Jan 2017 01:38 PM
Posted 16 August 2016 - 10:48 PM
Hey,
About to start building my 5k with 4k head.. but need head bolts seeing I can't get my hands on studs.. any one got an idea if I would have to buy 5k or 4k bolts? Or are they the same length?
The Granny 67 KE10
http://www.rollaclub...-daily-67-ke10/
Posted Image
KE10 Fan since 1999...
#2 ke70dave
ke70dave
    Well Known Member
  • Tech Moderator
  • 3630 posts
  • Online:Today, 11:35 AM
  • Gender:Male
Posted 17 August 2016 - 09:39 AM
If you have both heads there you could measure the bolt length required for both heads and compare.
Everyone is entitled to their own opinion, but not to their own facts.
#3 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Online:Yesterday, 10:11 PM
  • Gender:Male
Posted 17 August 2016 - 10:11 AM
When you are mixing heads & blocks, which may or may not have been skimmed or decked respectively, the best way is to measure the length required. It's not hard, but is important. If the head bolt is too long, it will bottom out in the threaded hole in the block, with all sorts of problems. If the bolt is too short, then not all the thread in the hole is used, with also possible ramifications of thread failure.
Clean the block threaded holes to make sure there is no rubbish in there. A tap helps. Measure the precise depth of the hole & note. Lay the head on its side & put a head bolt through the head, not forgetting to fit the hardened thick washer, under the bolt head. Put an old head gasket up against the head, & measure the length of thread sticking out beyond the head gasket, & note length.
This length should be approximately the depth of the block hole, previously measured, less the thickness of 2-3 threads of the head bolt.
I've always used this technique without problems.
It would be advantageous to use new bolts. The bolts you have are probably 30-40 years old & you never know how many times they have been tensioned. Head bolts stretch, each time they are tensioned, which is why manuals always suggest replacing them.
Hope this assists.
Cheers Banjo
Edited by Banjo, 17 August 2016 - 12:56 PM.
Keep them olde COROLLAs rollin !
#4 rke_011
rke_011
  • Regular Member
  • PipPipPipPipPip
  • 269 posts
Posted 17 August 2016 - 02:22 PM
Cheers.. seems there is no bolts in Australia.. well there are 2.. so I'll be looking into studs.. if anyone can point me in the right direction
The Granny 67 KE10
Posted Image
#5 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Gender:Male
Posted 17 August 2016 - 05:58 PM
Your predicament is not unknown. It's been mentioned on here previously.
Here is a previous post with a few ideas & P/Ns, from about 3 years ago.
http://www.rollaclub...7-in-australia/
Cheers Banjo
Edited by Banjo, 17 August 2016 - 05:59 PM.
#6 RainWarriorDregs
RainWarriorDregs
    Rust Eradicator
  • Regular Member
  • PipPipPipPipPip
  • 445 posts
  • Online:02 Jan 2017 01:40 AM
  • Gender:Male
Posted 19 August 2016 - 01:40 AM
I found in my adventure when building my 5k that the 5k headbolts are torque to yield bolts, meaning they cannot be used again once they are torqued down, and the 4k ones are not. However i myself believe that the 4k head bolts would also stretch, you could try finding an unopened 4k (there are a few getting around) and steal the head bolts out of that. My 5k was high high compression so it kept lifting the head and blowing the headgasket so i ended up going to Boltmasters (my local bolt shop) giving them my stock 4k headbolts and asking for some similar, they hooked me up and theyve been holding my head down ever since.
#7 Banjo
Banjo
    "Long Live the KE"
  • Senior Member
  • 641 posts
  • Gender:Male
Posted 19 August 2016 - 11:09 AM
Believe these are the studs ones you really need, which are available in the USA.
https://sportcompact...&Model=Corolla
Cheers Banjo
#8 joshua.mathews
joshua.mathews
    New Member
  • Members
  • PipPip
  • 27 posts
  • Online:16 Jan 2017 08:00 PM
  • Gender:Male
  • Real Name:josh
Posted 21 September 2016 - 09:11 PM
U can use 4age 16v head studs but u have to buy two sets as u can only use the long ones
#9 CorollaNut68
CorollaNut68
    Crash Magnet
  • Regular Member
  • PipPipPipPip
  • 227 posts
  • Online:28 Dec 2016 07:52 AM
  • Gender:Male
  • Real Name:Mark
Posted 24 December 2016 - 02:34 PM
Well guys...thanks to this topic and Dregs answer, it suddenly occurred to me that there is a Fastenal store not two blocks behind me. I've been considering ordering new bolts from RockAuto but they are $200. I'm about to bore and rebuild my 3K.
After reading this, I just looked and I can get SAE Grade 8's for about $2 apiece. Hmmm....$20 vs $200....what will I do? As long as these originals don't turn out to be some funky thread pattern. Gotta wait til after Christmas to find out though.
Thanks and Merry Christmas!
1968 KE10 Corolla 1100. Unknown miles when I bought it but I've added
759,008.4 miles 1,221,508.5 kilometers....so far
"I'll just drive this til I find something better" I said ...28 years ago....
#10 CorollaNut68
CorollaNut68
    Crash Magnet
  • Regular Member
  • PipPipPipPip
  • 227 posts
  • Gender:Male
  • Real Name:Mark
Posted 28 December 2016 - 07:10 AM
Well it's after Christmas...and he can't get them. I brought one of the Toyota head bolts with me, it has no marking except some kind of symbol but this guy thinks they are grade 11 or 12. I don't know these things. Do any of you?
#11 ke70dave
ke70dave
    Well Known Member
  • Tech Moderator
  • 3630 posts
  • Gender:Male
Posted 28 December 2016 - 12:36 PM
In general bolts are grade 8.8 or 12.9.
Havent ever heard of grade 11.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
