What Rwd Box For 3Mz V6 Ke26
  • Please log in to reply
4 replies to this topic
#1 diegoh
diegoh
    Regular Poster (Caption Editable Now)
  • Regular Member
  • PipPipPip
  • 94 posts
  • Online:08 Oct 2016 06:15 PM
Posted 07 October 2016 - 12:10 PM
Is anyone running a 3vz, mz or gr v6 in any front engined rwd pre 84 corollas celicas?
Ive been looking at the torque of all the toy v6 engines are their weights designs etc.
I will be happy with 230hp for a supercharged v6 as I'm interested in torque
VZ-e 8v heads are very light, cheap new and very compact for engine space.
The 3vz-e heads on a 3mzfe bottom end all head bolts line up and all water
galleries more or less match up, oil feed is spot on and oil drain is easy.
VZ-e e heads just need little opening up on water galleries after looking at
the gaskets its all very possible. Some oil drain holes on MZ need sealing etc.
Might seem a brain fart in a world of multivalve twin cams for everything
but at 8.2kg lighter each than 4v heads thats 16kg all up top! that I like.
M90 eatons are cheap from 3.8L buicks and single 2 inch SU is enough
no pollution gear is required here on birthplace Islands of Toyota :)
Is there a way to fit any 6 speed boxes for rwd or a way to fully manualize
some sort of modern 5 or 6 speed rwd lexus or ft86 transmission?
Edited by diegoh, 07 October 2016 - 11:05 PM.
#2 diegoh
diegoh
  • Regular Member
  • PipPipPip
  • 94 posts
Posted 07 October 2016 - 12:38 PM
For those wondering here is a pic of the 3vz vs mz bottom end
green is where to seal and even oil feed matches up.
Posted Image
Usually 3vz-e guys try just fit a 3vz-fe engine but I'm unconventional but all up the 3mz-e hybrid
service weight of 3mzfe is 157kg minus 16kg for lighter 3vz-e heads, lighter flywheel/clutch and
M90 eaton supercharger, compact inlet manifold & headers hopefully around 140kg
Edited by diegoh, 07 October 2016 - 12:55 PM.
#3 LittleRedSpirit
LittleRedSpirit
    Well Known Member
  • Global Moderator
  • 4344 posts
  • Online:Today, 10:45 AM
  • Gender:Male
Posted 08 October 2016 - 09:25 AM
From my research based around 2azfe I found the toyota v6 motors have similar bellhousing pattern to the s or az motors. Therefore its the typical y or s housing to suit w55 that will work best, it should centre on the dowels like the 2az does with s or Y, and three bolts shoold work and you can likely drill and tap more as I did. You might need to cut away some of the motor to fit a starter from the front ala rwd as the v6 engines you describe are usually starter from the rear.
The other problem is inlet manifold, as its complex to design and make fit.
Id prefer a 1gr with 5 speed behind it but that might be over the limit of ccs being 4 litre.
#4 diegoh
diegoh
  • Regular Member
  • PipPipPip
  • 94 posts
Posted 08 October 2016 - 06:13 PM
Thanks for that info, I worried about the starter but the inlet manifold I'm paying someone else to make it out of a piece of billet
as it ends up cheaper than tubing welds and flanges all up. Might even invest in a small billet charger than an eaton m90.
Posted Image
Edited by diegoh, 08 October 2016 - 06:17 PM.
#5 tdg61
tdg61
    New Member
  • Members
  • PipPip
  • 48 posts
  • Online:27 Nov 2016 04:16 PM
  • Gender:Male
Posted 27 November 2016 - 03:47 PM
Was originally going to do this in a ke20. I have a 3vzfe at home mounted to a 3vz bell housing which bolts up perfectly. Its out of a hilux v6. I think they use r150 manual boxes and should mount up too. Only problem is 3vzfe mounts starter on housing. But I'm sure with a bit of grinding and spacing you could mount one up. I know its been done before by someone on toymods. Also one of the Zoom magazine guys had a 3.5 Camry v6 in a 86 sprinter. Hope that helps a bit.
I'm Supercharged and I vote
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
