K40 - K50 Box (Ke70)
  • Please log in to reply
3 replies to this topic
#1 KaboomJohn111
KaboomJohn111
    New Member
  • Members
  • PipPip
  • 24 posts
  • Gender:Male
  • Real Name:John
Posted 27 December 2016 - 10:38 PM
I'm wanting to swap my k40 box to a k50 box
I've asked a few times if anything needs to be swapped
I know it is basically a straight swap, But I keep running into the same problem
Some say you need to put in the shifter from the k50 box, others say that the k40 shifter is fine in a k50 box etc. and most forums always end up with the discussion of shifter position betweeen KE20-30's (Forward), KE30-55's (Middle) and KE70 (Rearwards)
All I want is a clear answer, For this swap Do I have to change the shifter or are both interchangeable with one another
Also if the answer is that I have to put the K50 shifter with the K50 box, Please Give me and explanation why the two shifters are not interchangeable
I will in anycase put the k50 box with the K50 shifter since it came with it, But for future reference, and to clear any confusions for anyone (myself included)
Also I plan to find a short throw shifter for mine (because as many would know, the throw is long) Does anyone know who, or where to get one from (preferably brand new)
#2 Clapped out
Clapped out
    Wannabe Ke Salvage
  • Donor
  • 1063 posts
  • Online:Today, 09:37 AM
  • Gender:Male
  • Real Name:Rural bogan
Posted 28 December 2016 - 11:03 AM
Shifters between k40 and k50 FROM A KE70 are the same, only the earlier models before ke70 are different. Your gearbox will be a direct swap over in your ke70,
cheers!
Posted Image
I am a financial supporter of Rollaclub. You can be too.
Donate Here and support your forum.
#3 Nutta1
Nutta1
    New Member
  • Members
  • PipPip
  • 13 posts
  • Online:08 Jan 2017 09:15 AM
  • Gender:Male
  • CC BY-SA (recommended)
Posted 28 December 2016 - 04:25 PM
I did this many years ago the only drama I had was the clutch plate splines were different but I think that may have been a stuff up from the clutch and brake shop just check the number of splines before installing otherwise straight forward swap.
#4 KaboomJohn111
KaboomJohn111
    New Member
  • Members
  • PipPip
  • 24 posts
  • Gender:Male
  • Real Name:John
Posted 28 December 2016 - 05:16 PM
Thanks guys, hopefully this will help others too
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
