Search the Community
Showing results for tags 'My second KE70.'.
So me and my friends picked up another KE70. Thought I'd make a thread. Plans are to throw all the gear from the beige car into this and get it on the road so that means; - Standard Blacktop 20v with Sam Q water kit and velocity stacks. Also has SP Tec dizzy relocation kit. Running standard ECU. - Ebay spec alloy radiator with standard AE111 thermo mounted - W55 and my short shifter - Button clutch - T18 T series - 1L surge tank - Bosch 070 - VDO VL lift pump I've already thrown the suspension and brakes from the beige car into it so that's - BC coilovers up front, 8kg springs - AE86 hubs - ADM AE86 brakes (Cheers again Rian) - AE86 PS knuckles - AJPS 50mm RCA's - BC adjustable shocks in the rear with their 6kg springs and adjustable height spring seats - Whiteline adjustable panhard rod Wheels are 14x7 -5 Chevoit Centreliney things. Look like MK1's. Pretty cool I think. It's 5 speed and I'm going to rep 4K power until it all goes down. Plan is still primarily to go drifting but want to rego this one and drive it around so the setup will remain fairly mild. Was running -2.5 degrees of camber and 1mm toe out each side which I think is kinda streetable so I'll aim for that with my next wheel alignment. I have no real time frame for the conversion but I'd like to go drifting as much as possible next year, I didn't get to do it this year so I'll be happy if I can do it on a semi regular basis in 2013. Anyway, I've only got 2 pics at the moment but will take some more in the sun soon.
