Evan G Posted May 11, 2012 Report Share Posted May 11, 2012 how does it go for clearance in the tunnel? xmember requires new mounts? Quote Link to comment Share on other sites More sharing options...
Doogs Posted December 2, 2016 Report Share Posted December 2, 2016 Hey Si, Can you retain the K series Corolla spigot bearing? Cheers 1 Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted December 2, 2016 Author Report Share Posted December 2, 2016 I'm 99% sure you can, but can't confirm now cause I sold off all my w bits. Stu (tommys dad) could probably confirm as they're going to put a w50 in his 20.... using my old bell housing pictured. Quote Link to comment Share on other sites More sharing options...
kickn5k Posted December 3, 2016 Report Share Posted December 3, 2016 I'll measure up for you later this arvo. Quote Link to comment Share on other sites More sharing options...
Doogs Posted December 4, 2016 Report Share Posted December 4, 2016 I'm 99% sure you can, but can't confirm now cause I sold off all my w bits. Stu (tommys dad) could probably confirm as they're going to put a w50 in his 20.... using my old bell housing pictured. No worries Si, should be easy enough to confirm when I have everything on the ground. Just curious to see if someone knew. Cheers Stu Quote Link to comment Share on other sites More sharing options...
