Matts Ke30......sr20det
  • 4 weeks later...
So got some stuff done, i ran out of reasons not to bolt the front together.
The front bumper will cover the intercooler better so it should be pretty stealth.
I still need to buff the front gaurd before i put the bumper on. I probably should get it rechromed first anyway, as the rear one has been done.
Pulled out the nos stuff for the grill and shined it up, decided not to fit it yet though might wait till all the paint is buffed.
I made some mounts for an extra swaybar i had here, its made by kmac and mounts to the control arm supports. the old brackets were pretty crap so i made these out of alloy and some rubber bits i had here.
I put the badges and trims on the grill and guards, looks pretty good i say.
Tailshaft loop arrived
Made some new clear screen for the factory gauges, used some 3mm clear acylic i bought off ebay, the factory ones weren't real clear anymore.
Mounted the electric heaters under the dash on each side for demister.
and put the dash in finally.
Surge tank arrived 5 litres, still waiting on tig to arrive to do some mods to it.
Pulled sump pan off engine again, it hangs too low, so will do some mods to it to lift it up a bit.
  • Upvote 1
I have missed a few updates here it would seem.
bought a ktm 525 shim kit to do the cam shims, have done the inlet cam so far, Will still have to order the grooved type shim for half of them once i have the thickness right.
welded a flat bit of ally to the cooler pipe and tapped some 1/8 npt thread in there for wastegate line, and spare hole.
Made a fuel rail mount for top feed fuel rail to gtir quad throttles.
finished the boot wiring to battery and pumps, pumps arent wired yet though cos not mounted,
Made throttle cable mount out of stainless, works well.
Mounted gearbox oil cooler under car, ends up 130mm off the road so maybe a bad idea. cooler is 400 x 250 so fair sized.
painted some stuff, the clamps i had were only zinc so needed paint, and a few other things, tailshaft loop, fuel rail mount, ect.
so i bought a little lathe, can swing a 15" wheel, but no larger. still need to clear a spot in the garage for it.
put sr20de plate into cas and modded to work with ecu.
shims arrived today.
I have been putting some of the lines together, i bought the alloy shifter off ebay america, was quite surprised when it came, really good quality.
http://www.ebay.com.au/itm/350666738346?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
final undercoat
Edited by oh what a nissan feeling!
tailshaft loop.
shims done, clearances all good.
new fuel lines 1/2 inch aeroflow hardline black anodised.
I had 10mm lines in there but the fittings i used to join to the speedflow sucked badly and would never have sealed, so since i had to change the fittings i went to the bigger line.
The new fittings rocked up today too so i got to finish that off, much better fittings with the olive type joint.
Also fitted a billet trans dipstick as well, had to shorten it though as it would have been out the bonnet!
Tranny cooler lines done as well, had to hunt down an extra factory 90 degree fitting as things are pretty tight in the tunnel.
radiator hoses on.
rang around for a tailshaft, looks like $1200 will be spent, yikes! Not the cheapest quote i got, but this will get tranbrake so may as well do it once and right.
consists of:
1350 unis
billet output shaft
3.5" tube
custom rear yoke.
Had to go 3.5" tuba apparently due to 8000revs across the line.
test for 3.5" in tunnel
I have been practising tig alloy welding a fair bit, need to get some skill before i start on the fuel sytsem of the car, still a few weeks away yet.
pics from today
