Rolliac Posted May 6, 2008 Report Share Posted May 6, 2008 Hay folks. Does anyone know if Borg Warner and the Jap diff centers are interchangeable? The reason I'm asking is because it says in the FAQ that the KP starlet lsd center fits in the KE diff housing. But is that just the Jap diff? I have a Ke11 Borg that needs a center anyway. But i hear it's 5.7" and the KP starlet is 5.6". So if it does fit (the Borg has 23 spline axles if I count that correctly) would the crownwheel simply swop over? any help appreciated. Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted May 6, 2008 Report Share Posted May 6, 2008 i doubt borgie centres are interchangable with jap centres Quote Link to comment Share on other sites More sharing options...
Felix Posted May 6, 2008 Report Share Posted May 6, 2008 They don't. Quote Link to comment Share on other sites More sharing options...
Rolliac Posted May 6, 2008 Author Report Share Posted May 6, 2008 O well that settles it. thanks for that. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted May 6, 2008 Report Share Posted May 6, 2008 Go ask the same question on club-k.co.nz as I have been told by a very good authority on all things K that in can be done. Just remember exactly which models go, can't find thread I read it in, and their search function isn't working!! :POSTPICS!: Quote Link to comment Share on other sites More sharing options...
styler Posted May 7, 2008 Report Share Posted May 7, 2008 jap front loading (diff comes out front) the whole carrier comes out with centre so if the bolts are on the front it obviously unbolts from the front and the carrier come out, obviously is jap borg rear loading (diff comes out rear) remove the plate and take just the centre out by undo bracket bolts inside. if the bolts are on the rear they are the plate bolts, so undo them, remove plate and out she comes from the rear obviously a borg diff. for both jap and borg you need to remove both axles to remove a diff centre, take off wheels, take off drums, undo shoe spring, rotate hub window to each of the 4 bolts and undo, put drum on backwards with wheel nuts and impact it towards you until the axles send you arse over tit. laugh that you finally got them out. change diff centre and remember no more line lockers on a 6 inch diff. Quote Link to comment Share on other sites More sharing options...
Rolliac Posted May 7, 2008 Author Report Share Posted May 7, 2008 (edited) put drum on backwards with wheel nuts and impact it towards youuntil the axles send you arse over tit. laugh that you finally got them out. change diff centre and remember no more line lockers on a 6 inch diff. :hmm: I did exactly that. I gave up like 3 times but finally got e'm. And laugh I did. My diff is definitely Borg and the center broke in 2 right down the middle. So yeah I was just basically wanting to know if Jap and Borg centers are interchangeable. Edited May 7, 2008 by Rolliac Quote Link to comment Share on other sites More sharing options...
irokin Posted May 7, 2008 Report Share Posted May 7, 2008 So yeah I was just basically wanting to know if Jap and Borg centers are interchangeable. No, you cannot interchange parts between Borg Warner and Jap (banjo) diffs. You can however put a KP starlet center in a Jap corolla diff. Quote Link to comment Share on other sites More sharing options...
Rolliac Posted May 7, 2008 Author Report Share Posted May 7, 2008 Thanks everyone. Quote Link to comment Share on other sites More sharing options...
wenisman Posted March 13, 2020 Report Share Posted March 13, 2020 Hey guys, I'm just going down this is now, so I'm just following up and seeing if anyone still remembers, is it the kp61 starlet lsd that will fit into the jap ke housing? And if there is anyone still making these or where we can buy them? Quote Link to comment Share on other sites More sharing options...
parrot Posted March 13, 2020 Report Share Posted March 13, 2020 (edited) There was a guy in the Netherlands selling a used U code LSD centre a couple of weeks ago. BUT he was asking €750 for it if it wasn’t so expensive I probably would have bought it myself Edited March 13, 2020 by parrot Quote Link to comment Share on other sites More sharing options...
parrot Posted March 13, 2020 Report Share Posted March 13, 2020 Quote Link to comment Share on other sites More sharing options...
wenisman Posted March 14, 2020 Report Share Posted March 14, 2020 Hey parrot, Thanks, where did you see that posted? I looked in the buy and sell but I couldn't see it. There's one on auctions.yahoo.co.jp but it looks fairly abused. Cheers Quote Link to comment Share on other sites More sharing options...
parrot Posted March 14, 2020 Report Share Posted March 14, 2020 It was shared from the original face book post. Go to that starlet page Quote Link to comment Share on other sites More sharing options...
