my car has recently been shaking really bad whenever i stop. and there is a really loud banging noise i think its coming from the motor and i can't figure out what it is. also what can i do to my car to increase its performance? :D
Hay
Maybe you need new engine mounts/gear box mounts.
check them out
cheers shaun.
First thing you can do to increase its performance is get rid of the shaking and banging.
Actually, don't even think about "what can i do to my car to increase its performance" until you've diagnosed the banging and the shaking - that just doesn't sound good :fuzz:
firstly, there's not a hope in hell that anyone can help with such a broad description of the problem ...
we need some more detail and some specifics.
For example:
this could easily be caused by 16 belly dancers in the boot who start their gyrations only when the vehicle is stationary.
remedy: get the 16 belly dancers out of your boot and tell them to go home.
this could easily be caused by one of the belly dancers who got into the engine bay by mistake (she meant to get into the boot with the others) and is now banging on the underside of the bonnet to be let out.
remedy: get the belly dancer out from under the bonnet and tell her to go home.
seriously though ...
Is it shaking as you come to a stop?
What sort of shaking? Side to side, up and down, fast, slow ???
Does it feel like it's coming from the back of the car or the front?
Does the brake pedal pulsate under your foot?
Does the steering wheel shake in your hand?
What sort of banging?
High and tinny, deep and thumpy?
Does it speed up when you rev the motor?
Is it in time with the shaking?
(for example)
suspect:
  • engine mounts
  • warped discs
  • out of round drums
  • tyre tread separating
  • tyre out of round
  • wheel out of balance (detached weights, mud adhering to rim etc)
  • worn suspension components
  • big end bearings
  • piston conrods
  • dropped valve
  • torn fan belts
  • worn CV joints
  • faulty universals
cheers,
Slapper
Edited by slapper
Actually, don't even think about "what can i do to my car to increase its performance" until you've diagnosed the banging and the shaking - that just doesn't sound good :D
For example:
(for example)
cheers,
Slapper
its deep and thumping. the whole car shakes from side to side when i come to a complete stop. it doesnt do it while the car is moving or slowing down. i think i need motor mounts but i have needed them and it has recently gotten alot worse
hmmm ... side to side on a front-wheel-drive is kinda interesting ...
I assume you mean when the car is stationary and idling.
does it change with rev's at all?
does it do it if you coast along with the clutch in and the engine idling?
I'd be checkinbg engine mounts first.
cheers,
Slap
cheers,
Slap
its stops when it revs and when it coasts with the clutch in it doesnt do it either but i will check the motor mounts. hopefully thats all that is wrong with it
thanks misti
are you giving food and water to the hookers in the trunk? 'cos they get agitated when they're hungry and dehydrated... Kicking and thrashing about etc... would explain the rocking.
