1972 Ke20 Sr20Det 2017 Update
MYT B OLD
Can you let us know how much the tank cost?
Hey mate, the fabricator said between $1300-$1400 to construct the same tank or similar depending which ke. By the time you include the same parts it will bring it to about $2500. Than from there all your bulkhead fittings, solid lines to engine and back etc.
I am very happy I've gone for something like this as it sits in the factory mounting points and is a lot bigger. All the pumps are in one place not having to worry about having them under the car. You also have the room to throw in a spare tyre as per the design to allow you (in my case a 195 50 15 fits no problem)
wow that tank looks so good, i was going to do the welding on mine myself, i don't think i will after seeing that! so tidy.
When I look at it it looks like a headache but after it was made it came up great. The welding on it is superb.
Link to comment
Share on other sites
  • 1 year later...
It has been a while since last update but the car is nearly up and running, if all goes to plan this Saturday :)
Here are pics of all the work that I missed to update
Exhaust with vbands, magnaflow muffler, proflow cat
12346221_514526658725470_2122792802_n_zp
12331958_951042388282671_213345737_n_zps
Cold air intake with box
12317599_1122766134413900_1752432421_n_z
12356575_761295420666360_646466490_n_zps12407718_573954296104508_242541857_n_zps
12362373_936265213121134_449439997_n_zps
Catch can
12353809_213643282305718_651002551_n_zps
72A0142B-9791-47A0-839E-FA5F50F81BC7-261
Edited by MYT B OLD
  • Upvote 1
Link to comment
Fully rewired the entire car by one of local auto sparky guru's. It was my biggest job and has come up a treat. All new wires, plugs, all new connectors and plugs for the whole engine harness. Has a bulkhead on the firewall for easy engine removal. Also did a Yaris cop conversion and running Bosch 1650cc injectors.
Link ECU and lots of plugs
A8D74A1D-CD6C-4512-BD4B-22F318E0D6EA_zps
899B538C-3308-4CFE-968B-A241ED595D90-775
Fuel system wiring
9C2EDD70-AEF4-42F6-9771-50B0E4010B93-186
Engine harness + bulkhead
1434CF6D-682C-4BF5-BD32-6C96A32EC264-175
H4 headlight conversion
8289516C-ECBA-4F09-ABA3-91CA90F75932-484
Battery in boot + isolator
4C8C6BDF-28A4-40B6-9CB7-73388747CD08_zps
New fuse box and relay mounted up
4B778678-402D-4FCF-BCB5-F341F6BEAD86_zps
Ecu and relays
441F1D85-1A12-4622-906D-2CD0E44B5D1D_zps
Custom suede dressed dash all lit up
B3A8D189-678E-4E7C-84F9-3B9A04E2DE7B_zps
Turbo and wastegate braided lines during making of lines etc. The cable ties in there aren't on and there are billet hose line seperators
FCD5272E-B19A-4E26-81A1-2F866E63799E-340
F7B803B8-80DD-4706-8C2A-CF192BFEEA9A-340
Turbo cover writing shaved off and same with valve cover. This is pretty much the most recent pic as it stands
E6B96F2E-5BA3-4E1B-BCE5-113AF711B95D_zps
Also got new tyres on the front in Continental 195 50 15's and Hankook RS3's in the back in 225 45 15. Got whitewalls added too for that perfect finish and have some new moon caps and rings to go on the outer rim lip.
290F3088-7B23-48A6-9022-C9F0FEB641B8_zps
Edited by MYT B OLD
Link to comment
