Jamin1 Posted July 4, 2010 Report Share Posted July 4, 2010 hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance Quote Link to comment Share on other sites More sharing options...
xmoht Posted July 4, 2010 Report Share Posted July 4, 2010 hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance I wouldn't say it's ripping your 4k out for nothing. If you actually have every other component set up to do a CA18 conversion and the only thing you have left to do is a few mounts, then you're laughing. Quote Link to comment Share on other sites More sharing options...
rb20 rolla Posted July 4, 2010 Report Share Posted July 4, 2010 hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance i know it's not a ca18 and the 4k mount's been cut down a bit but you can see the rb20 mount slides into the 4k one you have to grind the little tab off the rb20 one and grind the 4k side a little, as for a straight bolt in i have herd it does but never seen it so i can't confirm that one so i hope this helps a bit. Quote Link to comment Share on other sites More sharing options...
johnnyblz Posted July 4, 2010 Report Share Posted July 4, 2010 hey mate, ive just done this conversion and tried to do rb mounts. yes the ca engine mounts bolted up to factory ke crossmember with rb mounts, BUT the engine sump was about 60mm off the crossmember. so we welded custom mounts onto the ke crossmember to suit to get engine lower. Quote Link to comment Share on other sites More sharing options...
SLW42 Posted July 4, 2010 Report Share Posted July 4, 2010 hey mate, ive just done this conversion and tried to do rb mounts. yes the ca engine mounts bolted up to factory ke crossmember with rb mounts, BUT the engine sump was about 60mm off the crossmember. so we welded custom mounts onto the ke crossmember to suit to get engine lower. what is this said mod in? And how much lower did you get the motor in the car? Quote Link to comment Share on other sites More sharing options...
chestikoph1 Posted July 4, 2010 Report Share Posted July 4, 2010 hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance Hi mate, Mounting the engine is probably the easiest part of any engine conversion, so don't limit your choice because you think it might be hard to put in something else that may require custom mounts. Its all the other things that come with doing an engine conversion that will give you the shits. But its all fun :hmm: Quote Link to comment Share on other sites More sharing options...
Jamin1 Posted July 4, 2010 Author Report Share Posted July 4, 2010 i know it's not a ca18 and the 4k mount's been cut down a bit but you can see the rb20 mount slides into the 4k one you have to grind the little tab off the rb20 one and grind the 4k side a little, as for a straight bolt in i have herd it does but never seen it so i can't confirm that one so i hope this helps a bit. my mate just got a rb20 with mounts that don't have that pin don't know why and for a street car is 60mm off that bad? i was just hoping for no welding/cutting involved Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted July 4, 2010 Report Share Posted July 4, 2010 u want to do a conversion and don't want to weld or cut :hmm: , what r u going to do when u get to your tail shaft and diff let alone your gearbox mount Quote Link to comment Share on other sites More sharing options...
Evan G Posted July 4, 2010 Report Share Posted July 4, 2010 must be school holidays agian...... Quote Link to comment Share on other sites More sharing options...
johnnyblz Posted July 5, 2010 Report Share Posted July 5, 2010 what is this said mod in? And how much lower did you get the motor in the car? engine is in my ke70 this pic is how high or low its mounted, Quote Link to comment Share on other sites More sharing options...
SLW42 Posted July 5, 2010 Report Share Posted July 5, 2010 Thats pretty cool man so thats just the stock k crossmember mounts cut off and positioned where you want wicked, lucky you can weld haha, Quote Link to comment Share on other sites More sharing options...
johnnyblz Posted July 5, 2010 Report Share Posted July 5, 2010 Thats pretty cool man so thats just the stock k crossmember mounts cut off and positioned where you want wicked, lucky you can weld haha, yep prety much, steering rack is quite close, also i would recommend if you wanted it to be a street car to do rb box on the ca bellhousing for much better shifter position and less chopping of the car. Quote Link to comment Share on other sites More sharing options...
SLW42 Posted July 5, 2010 Report Share Posted July 5, 2010 yep prety much, steering rack is quite close,also i would recommend if you wanted it to be a street car to do rb box on the ca bellhousing for much better shifter position and less chopping of the car. yeah mine is gonna be a street car but i'm using the ca crossmember, i was thinking about rb box with a ca front Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted August 11, 2010 Report Share Posted August 11, 2010 ca18 crossmemeber wont work u will need to fabricate one using the ca rubber gearbox mount very easy using some 25-30mm box section and some flat bar. Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted August 11, 2010 Report Share Posted August 11, 2010 what model you putting the ca in by the way? Quote Link to comment Share on other sites More sharing options...
