rke_011 Posted September 30, 2010 Report Share Posted September 30, 2010 (edited) We have done it, ecotec v6 into a ke70, the conversion isnt that hard to do if you have a bit of mechanical knowledge. The sump fits between the x-member and swaybar. custom mounts and gearbox crossmember need to be made, as do custom extractors and tail shaft. easy peazy... were also building a v8 one aswell :) Edited September 30, 2010 by rke_011 1 Quote Link to comment Share on other sites More sharing options...
78corolla Posted October 6, 2010 Report Share Posted October 6, 2010 got any more info of pics of mounts and cross member, what sort of beating will the trans tunnel need to cop or is it a case of cutting it out and re fabricating one, i am looking at doing an ecotec conversion as i have alot of gear left over from a turbo set up on my ute Quote Link to comment Share on other sites More sharing options...
KE70+AE92 Posted October 6, 2010 Report Share Posted October 6, 2010 i also just put a old 3.8 out of a vr into my ke70 allot of custom work and the wirings a night mare make sure if ur using a motor from vr onwards u have the bcm or the car wont start or get the security removed from the memcal like i did in mine. Quote Link to comment Share on other sites More sharing options...
KE20 V6 Turbo Posted January 18, 2011 Report Share Posted January 18, 2011 i also just put a old 3.8 out of a vr into my ke70 allot of custom work and the wirings a night mare make sure if ur using a motor from vr onwards u have the bcm or the car wont start or get the security removed from the memcal like i did in mine. Have you managed to register one? Engineered? I'm in the process of doing a KE20 and was thinking to rego it if its possible. Ive already gone 10.30@135 in a VP Commodore and have a more grunty motor in mind for the KE20. Though it will be N/A for the engineers... Quote Link to comment Share on other sites More sharing options...
KE70+AE92 Posted January 19, 2011 Report Share Posted January 19, 2011 its not gonna be registered its a track car :) Quote Link to comment Share on other sites More sharing options...
KE20 V6 Turbo Posted January 19, 2011 Report Share Posted January 19, 2011 its not gonna be registered its a track car :) Thats fair enough. Ill keep trying :wink: Quote Link to comment Share on other sites More sharing options...
rolla76* Posted March 22, 2011 Report Share Posted March 22, 2011 hi there i am want to put a v6 vn or vp engine auto I'm my rolla 4 door ke 30 what do i have to do to get it in there any help plz.... Quote Link to comment Share on other sites More sharing options...
soa.rota Posted April 7, 2011 Report Share Posted April 7, 2011 Ive got the engine loom box an everything needed to bolt it straight into my ke30. The only thing i need is cross member an engine mounts. Can someone give me some help on which ones to use or where i can get some ? Quote Link to comment Share on other sites More sharing options...
SLW42 Posted April 7, 2011 Report Share Posted April 7, 2011 read the previous posts guys it states YOU NEED CUSTOM ENGINE MOUNTS, so in other words get an engine crane, drop the motor and box into it where you are happy with it and then grab a welder and start making some mounts :jamie: Quote Link to comment Share on other sites More sharing options...
fish and chips Posted April 12, 2011 Report Share Posted April 12, 2011 i have everything needed to do the convertion but all i need toknow is what do you have to do to the trany tunnle to get the commo tranny to fit? Quote Link to comment Share on other sites More sharing options...
aarex7 Posted April 29, 2011 Report Share Posted April 29, 2011 (edited) i have everything needed to do the convertion but all i need toknow is what do you have to do to the trany tunnle to get the commo tranny to fit? an angle grinder????? anyway I'm a bit late seein this but ive done it works great i drift it whenever i can! ive been drifting it for close too 2 years now. if anyone is interested hers a link! http://www.ae86drivingclub.com.au/forums/showthread.php/16076-holy-roller Edited April 29, 2011 by aarex7 Quote Link to comment Share on other sites More sharing options...
SXEGM8 Posted June 27, 2018 Report Share Posted June 27, 2018 On 9/30/2010 at 4:53 PM, rke_011 said: We have done it, ecotec v6 into a ke70, the conversion isnt that hard to do if you have a bit of mechanical knowledge. The sump fits between the x-member and swaybar. custom mounts and gearbox crossmember need to be made, as do custom extractors and tail shaft. easy peazy... were also building a v8 one aswell Hey mate I'm just about to start my v6 conversion in my ke70 I've got the engine mounts, gearbox mounts and everything else. Just wanted to ask you how you wired it up and how did u do the loom Thanks mate Quote Link to comment Share on other sites More sharing options...
