Mighty tas rolla Posted November 1, 2010 Report Share Posted November 1, 2010 Hi got a bit of a problem with my 4age conversion and need some help i have got a blue top 4age with a map sensor & tvis and am unsure which ecu i need the engine is origanaly a rwd so does that make it jdm??? anyway the ecu plugs are yellow any help gratefully appreciated Marcus Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted November 1, 2010 Report Share Posted November 1, 2010 Hi got a bit of a problem with my 4age conversion and need some help i have got a blue top 4age with a map sensor & tvis and am unsure which ecu i need the engine is origanaly a rwd so does that make it jdm??? anyway the ecu plugs are yellow any help gratefully appreciated Marcus Unless I'm otherwise mistaken, an ECU from a FWD AE82 Twincam should suffice, as they ran MAP bluetops in the earlier models. If the motor is indeed an orignal RWD one then yes it would be JDM (most likely from an AE86, or possibly an AA60 Celica) Quote Link to comment Share on other sites More sharing options...
