xangomatt Posted April 1, 2011 Report Share Posted April 1, 2011 ke30 has hard time getting from 90-100km, any thoughts? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 1, 2011 Report Share Posted April 1, 2011 Its probably because its an old crap 3K. Do a full service and tune, if it doesnt help put a 4 or a 5K in it. 1 Quote Link to comment Share on other sites More sharing options...
Evan G Posted April 1, 2011 Report Share Posted April 1, 2011 +1^^ Quote Link to comment Share on other sites More sharing options...
Spencer[RL] Posted April 1, 2011 Report Share Posted April 1, 2011 NOS Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 1, 2011 Report Share Posted April 1, 2011 NOS I'd pay to see that on a stock 30 that struggles to 100. :lolcry: Quote Link to comment Share on other sites More sharing options...
Spencer[RL] Posted April 1, 2011 Report Share Posted April 1, 2011 :laff: Quote Link to comment Share on other sites More sharing options...
Sloth Posted April 1, 2011 Report Share Posted April 1, 2011 +1 to NOS And a VTec sticker, that will add +5hp. I would also consider adding some neons. (If you are being serious though and this isn't an april fools joke, then my comments would be the same as blzbub, the 3k is a 30 year old engine that isn't really built for performance) Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 1, 2011 Report Share Posted April 1, 2011 ke30 has hard time getting from 90-100km, any thoughts? terrorists. Quote Link to comment Share on other sites More sharing options...
jono1986 Posted April 1, 2011 Report Share Posted April 1, 2011 My 3k 3spd didn't have trouble doing that sort of thing, like blzbub666 said do a service and tune then go from there. Quote Link to comment Share on other sites More sharing options...
Old fella Posted April 1, 2011 Report Share Posted April 1, 2011 G`day mate, you`re a hard one to convince aren`t you. The 3k needs at least rings. The same as you were told when I advertised it and the same as when you bought it from my son. The engine will never run correctly until the rings are replaced. It burns oil like there is no tomorrow. Get it,,,,got it,,,,good. Quote Link to comment Share on other sites More sharing options...
philbey Posted April 1, 2011 Report Share Posted April 1, 2011 Case Closed! Quote Link to comment Share on other sites More sharing options...
xangomatt Posted April 2, 2011 Author Report Share Posted April 2, 2011 I fixed the oil burning issue and changed the head gasket and valve seals. she works fine now, didnt have to do the rings. just a case of a weak engine needing the cob webs knocked out. just about done rebuilding the 4k which i will drop in next month. It only burned oil first day or so of running it but stopped after running it a while and changing gaskets. There was nothing about convincing! Just a simple question. G`day mate, you`re a hard one to convince aren`t you. The 3k needs at least rings. The same as you were told when I advertised it and the same as when you bought it from my son. The engine will never run correctly until the rings are replaced. It burns oil like there is no tomorrow. Get it,,,,got it,,,,good. Quote Link to comment Share on other sites More sharing options...
Andy43 Posted April 3, 2011 Report Share Posted April 3, 2011 Agree Tune up !!!! Do all the stuff, Oil, All filters (Air, Fuel oil), plugs, points, cap, rotor, if the leads look old change them too. Inspect the the plugs this should tell you how the carby is running . Check compression about 125 psi is the lowest you should see and all cylinders should be about the same. Be sure you check the timing, Id set to 10 and back off the 8 if it pings, you need to disconnect vac line to dissy when setting timing. Have a good look at the carby make sure the flapper vavle is working. Check the exhaust and make sure its not been flattend. Is it burning oil ? Is it losing water ? Cheers Andy Quote Link to comment Share on other sites More sharing options...
towe001 Posted April 4, 2011 Report Share Posted April 4, 2011 Araldite fixes everything :jamie: Quote Link to comment Share on other sites More sharing options...
RA28GT Posted April 8, 2011 Report Share Posted April 8, 2011 I'm pretty sure it's the nature of a 3k? I don't go over 80km/h with my 4.3 ratio diff. At least you can get 90! Quote Link to comment Share on other sites More sharing options...
