#ALLORman
How To Wire Up Head Unit In A Ke70.
hey guys, just got my first ke70 and need help wiring up the head deck
i have all the gear
just a bit confused on what wires are what for the unit
if any one knows or has a diagram please let me know
thanks.
heres a photo, i know its hard to tell just let me know. post-14144-0-34560700-1312800646_thumb.jpg
Share this post
Link to post
Share on other sites
not sure what plugs what, but you need to hunt down the wire (with a test light) that only has power through it when the ignition is on .. than find the second wire, which will have constant power.. the one that only has ignition power goes to the yellow wire on your head unit normally, and the constant goes to red.. although refer to your user manual for the cd player.
from there just guess what wires are the speaker wire, and which side is which wires etc.. i usually just chop the whole harness off and solder wires from there.
Share this post
Link to post
dude run new wiring,
take a run off the cig lighter for the +switched
+ battery will need a new line from the battery WITH a fuse
run new speaker leads as the factory ones are crap
-ground just screw into a metap part near the headunit to the body
thats pre much it
Share this post
Link to post
I have found its ALWAYS better to run new wiring when doing an aftermarket stereo install. The old thin wires they use for factory stereo's back in the day were not made to handle the amount of juice we want to run through it.
You might end up blowing fuses, melting wires, or just totally crap sound.
fresh is always best! :)
Damo
  • Upvote 1
Share this post
Link to post
I know this is digging up an old thread, but wiring up my head unit i couldnt find a wire from the stock HU that had constant power, where can I splice one off of?
Share this post
Link to post
I ran my own constant power direct from the battery . And then Spliced accessories from the defogger button for the rear window .
Worked perfect
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
