drift freak Posted April 16, 2012 Author Report Share Posted April 16, 2012 Yeah I know Jordain. Once it's all in their and the leafs are flattened I reckon there will be enough room to get it past :) I probably wouldn't have made it so wide if I did it again but too late now :) Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 14, 2012 Author Report Share Posted May 14, 2012 Well I've made some more progress in the last couple of weeks. I received my inlet manifold from Glenn (Celica RA 45) so I have now installed my blacktop quads and set up the temporary linkage system. I will have to sort something out in the future as the linkage fouls on the rocker cover and is in the way of the rocker breather hoses. Glenn has a centre pull linkage setup from underneath for sale but I will try and make my own first. Next will be sourcing some velocity stacks and air box. Although I will probably have to make a custom box as it sits so close to the firewall at the moment. I was surprised as the TPS plug from the Beams loom plugged straight into the quads TPS plug. Bonus!!! No I have also had my EF XR6 LSD diff cut down and axles sent for resplining. I have mounted it on the rea leaf springs using Kustom Bitz mounts I purchased directly from Kustom Bitz in Victoria. I am yet to weld the mounts on as I need to see if the diff rotates at all once it is on the ground with the wheels on. I also need to have the wheels back on to help locate the diff centrally (equal space between wheels and guards) Hope full some more updates soon with my axles expected back this week :) Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 18, 2012 Author Report Share Posted May 18, 2012 Just some more photos of the brakes on. Now I need some wheel nuts to pull the studs back through and then I can fit some wheels and look at setting the ride height in the back :) Prgress is finally starting to come together, it is at the most complete stage since I bought the rolling shell nearly a year and half ago lol Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 21, 2012 Author Report Share Posted May 21, 2012 Well I spent yesterday banging round in the shed and made some more progress. I re-fabbed the fuel cradle to give me some extra room for the exhaust. Then I made some lowering block from 50*50mm box tube. These are quite easy to make, I drilled a 12mm hole through both sides for the locating pin and then reamed one side out to 14mm to suit the locating pin on the spring. Then I got stuck into re-making the centre floor brace so I can put some seats in the front again. Man this is a slow task as it requires cutting and grinding until the folded brace sits nicely over the tunnel. Below is the first mock up I have attempted. I will be getting some more tube but painted instead of galvanised for the final version. I also got a couple of under carraige shots for those interested in the suspension layout. So as you can see things are moving along nicely. i am pretty happy with how it is all coming together. Once the fabrication work is finished it will be onto the body for rust repairs, then paint and interior :) Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 23, 2012 Author Report Share Posted May 23, 2012 Finally got the old girl rolling today. It had been way too long. Once I'd gotten over the fact that it was rolling I pushed her back in the shed (for some more photos) Then i got stuck into making the floor brace piece. Still going with that. Quote Link to comment Share on other sites More sharing options...
wrathchild Posted May 25, 2012 Report Share Posted May 25, 2012 lookin good Luke lookin good! :) Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 26, 2012 Author Report Share Posted May 26, 2012 Cheers wrathchild, it's finally starting take shape. After so many different combinations it rolls, sits nice. Now for steering and brake pedal setup.... To be continued..... Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 28, 2012 Author Report Share Posted May 28, 2012 So I've made some more progress peeps. I spent most of Sunday working on the central floor brace so I could put my seats back in and start sorting out the steering column setup. I folded, cut and welded a piece of 125mm*75mm*3mm box tube into place then made up adapter tabs to install the seat braces. I have now welded the drivers side mount back in and reinstalled the drivers seat, along with the steering column. I am pretty stoked with how everything fits apart from the lack of foot space in the drivers footwell. So as you can see things are extremely tight so it will be race shoes only while driving or barefoot LOL. So now the drivers seat is in, I will taking the old girl to a local hotrod shop next Tuesday to have the steering rack professionally installed. Until then I will concetrating on the fuel tank enclosure in the back. I would like to get it covered and fuel lines setup. Oh another shot :) Thought Id put up a shot of roughly how the dash will be setup, very simple but I think it will look smick once its all in there and finished. Quote Link to comment Share on other sites More sharing options...
oldie Posted May 29, 2012 Report Share Posted May 29, 2012 couldn't you notch the wheel well a little to give a bit more pedal space,a gentle massage with some heat and a hammer,no cutting/welding needed? Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 29, 2012 Author Report Share Posted May 29, 2012 Oldie, do you mean the gear box tunnel (notchin??) the tunnel is pretty tight against the gearbox so there isn't much room to do anything unfortunately. Was thinking maybe an auto instead??????? Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted May 29, 2012 Report Share Posted May 29, 2012 lol. Just cut 2 toes off each foot and use 3/4 scale pedals. Or bind your feet like an 18th century Chinese housewife. :yes: Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 29, 2012 Author Report Share Posted May 29, 2012 Little red spirit - maybe a workplace accident with the ride on is in order, trim my feet to appropriate size and also get enough money to finish it ASAP. LOL. I think with small shoes and some practice it will be fine. Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 29, 2012 Author Report Share Posted May 29, 2012 Oldie, I just re-read your post. Wheel well. Maybe it would be possible but it will hav to wait until everything is in and sorted, don't want to lose any suspension movement or lock. Quote Link to comment Share on other sites More sharing options...
13BT_KE20 Posted May 29, 2012 Report Share Posted May 29, 2012 If you run enough negative camber and positive caster you shouldnt get anywhere near the rear of the wheel well. Wait and see but you should have plenty of room to enlarge the footwell area. Really like what your doing with the car, wish i could weld! Cheers Quote Link to comment Share on other sites More sharing options...
drift freak Posted May 29, 2012 Author Report Share Posted May 29, 2012 Thanks 13BT_ke20 yeah I'm pretty sure I can modify it as I already have to reshape the front edge of theguard because the tyre scrapes. Weldon is a funny thing, it's all in the preparation, making sure it's clean and bare metal are the key. I've only tacked most stuff in as I'm gunna getthe shell fully sand blasted. Then I'll repair the rust and fully weld everything up including stitching the shell :) Quote Link to comment Share on other sites More sharing options...
