orangeLJ Posted December 10, 2012 Report Share Posted December 10, 2012 (edited) with the double flares, you will often need to tighten them up as hard as possible (allowing both ends to "bite" into each other) a couple times to get a good surface seal. Edited December 10, 2012 by orangeLJ Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 11, 2012 Author Report Share Posted December 11, 2012 Ah such a pain in the arse!!! I should have given myself a little more clearance behind the pedals as its almost impossible to get the spanner on the firewall bulkhead nuts. A few people hav said the same thing about tightening them a few times to ensure good sealing. Very frustrating part of the build that's for sure Quote Link to comment Share on other sites More sharing options...
orangeLJ Posted December 18, 2012 Report Share Posted December 18, 2012 the first time I made lines up it did my head in! I'd flare them perfectly, botl it all up, go to bleed..... leaks.... pull it all down, inspect, no problems, put it back together and no problems! haha Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 19, 2012 Author Report Share Posted December 19, 2012 So how did you get them to seal properly??? Did you just tighten and loosen a few times to create a good fit?? Quote Link to comment Share on other sites More sharing options...
orangeLJ Posted December 19, 2012 Report Share Posted December 19, 2012 basically yeah, did them up ʞ©$ɟ off tight, undid them, did them back up reasonably tight. Just be careful of the flare nuts if you are re-using old ones. (you've probably realised how ʞ©$ɟing soft they are!) A good quality set of pipe spanners are invaluable. Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 20, 2012 Author Report Share Posted December 20, 2012 Yeah cheers for the heads up :) I will be grabbing myself a set of tube spanners ASAP. Like you said they are totaly invaluable as I've come to realise!!! I just wish this flare tool would hurry up and arrive, I have some time off over the new year and want to get this done. Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 28, 2012 Author Report Share Posted December 28, 2012 So I finally had my brake flare tool arrive the other day and have since put the brake and clutch lines together. To be honest buying the Eastwood Brake Flare Tool was easily the best tool purchase I've ever made. I got it out of the box and within minutes was creating perfect flares for what I needed. So now the coupe drives and stops which has put a massive smile on my face and has made my xmas/new year just a little less stressful. Check it out So now its time to start stripping it back to pieces and start finishing the body and get it ready for paint. Watch this space :) Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted December 28, 2012 Report Share Posted December 28, 2012 Awesome, jelly of your shed ;) Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 28, 2012 Author Report Share Posted December 28, 2012 Cheers b.l.z bub, yeah years of overtime and no social life got me the shed. Definitely wouldn't have started such a massive project without it. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted December 28, 2012 Report Share Posted December 28, 2012 Having room makes life so much easier. Mine isnt huge but compared to my garage at home its massive. Being able to walk around my car and open all the doors was so good. Garage: Shed: So much room for activities. Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 28, 2012 Author Report Share Posted December 28, 2012 (edited) Wow your wagon is smick! Nice work 👍 yeah I'd be lost without my shed plus it gets me out of the fiancé's hair lol Edited December 28, 2012 by drift freak Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted December 28, 2012 Report Share Posted December 28, 2012 can't take credit for the wagon, all I did was the lip, wheels and lowering. Best bit about my shed is its at the missus parents and they have a pool, so we all go and I get to tinker and they get to swim. Win win :P Plus nothing better than sweating your ass off and being able to walk 20 meters and jump in a pool. :y: Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 28, 2012 Author Report Share Posted December 28, 2012 Damn I wish I had a pool. I can't complain to much though I have a river 5min away and the ocean is 15min. 1 Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted December 29, 2012 Report Share Posted December 29, 2012 Purrs like a kitten. :clover: Quote Link to comment Share on other sites More sharing options...
drift freak Posted December 29, 2012 Author Report Share Posted December 29, 2012 LittleRedSpirit - Yeah it idles pretty well for now. I was lucky enough to get a ecu config file from a guy in Berridale who I met online (massive props T. Duncan for sharing his tune with me). It has saved me a hell of a lot of work but it still needs fine tuning on a dyno to sort out all the fiddly settings and stuff. It will do for now to move it around though. Not entirely sure about the brake system, I think I might need to put in boosters as the pedal is fairly stiff. It does stop reasonably well though so I need to borrow my mates brake testing machine and get some stopping g-force readings and pedal pressure figures, this will allow me to determine whether the booster is needed or not in relation to the RTA braking specs. Hopefully I can sort this in the next week or so...... Quote Link to comment Share on other sites More sharing options...
