scottiriver Posted December 20, 2011 Report Share Posted December 20, 2011 hey all, i walked into sprint carburettor and fuel injection service today and the guy told me that the weber 32/36 uses the same jets as the 2L cortina and escort, is this true? will it run well on a 4k? cheers Scott Quote Link to comment Share on other sites More sharing options...
Evan G Posted December 20, 2011 Report Share Posted December 20, 2011 32/36 is a very common upgrade on k motors Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted December 20, 2011 Report Share Posted December 20, 2011 hey all, i walked into sprint carburettor and fuel injection service today and the guy told me that the weber 32/36 uses the same jets as the 2L cortina and escort, is this true? will it run well on a 4k? cheers Scott The 32/36 IS the carb fitted to the 2L pinto motors in the Escorts and Cortina's Quote Link to comment Share on other sites More sharing options...
BlueKsev Posted December 20, 2011 Report Share Posted December 20, 2011 If you got one off an Escort or Cortina, it would need re-jetting before it would work with a 4k. If that's what you mean? Quote Link to comment Share on other sites More sharing options...
jimmy-d Posted December 21, 2011 Report Share Posted December 21, 2011 talking about webers on a 4k,a 4k that has a weber fitted and runs like shit till it warms up,is this a tuning and or jetting problem,is it normal or what else could it be??this is all the info I have at present so just opinions,ideas would be appreciated.. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted December 21, 2011 Report Share Posted December 21, 2011 Is the choke on the Weber hooked up?? Quote Link to comment Share on other sites More sharing options...
BlueKsev Posted December 21, 2011 Report Share Posted December 21, 2011 Any motor started cold without the choke will usually do that, on some motors it may be hardly noticeable, some it will be hardly driveable. I haven't got around to making up a choke cable so i run without it, and it's not fun. Actually while I'm thinking about this, i might have a go at hooking one up today. Cheers :) Quote Link to comment Share on other sites More sharing options...
Mezz/// Posted December 22, 2011 Report Share Posted December 22, 2011 I have a 32/36 on mine and it does the same,..then when warm it will run sweet. I do have a set of extractors,oversized valves,a cam,so maybe this helps as I need more fuel maybe?! Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted December 22, 2011 Report Share Posted December 22, 2011 Why don't you Weber boyz get a pinned thread up where you can list mods and jet sizes. You will need to rejet the carbs (idle jet, air jet and main jets) to suit the 4K, and again to suit the cam & exhaust you have fitted. So that is time on a dyno with an oxygen meter, or a built-in oxy sensor & fuel mixture display. If the guys who did them years ago post up their figure then it will be quick & easy for people doing it now. Quote Link to comment Share on other sites More sharing options...
Mezz/// Posted December 23, 2011 Report Share Posted December 23, 2011 Ok Altezza :) I'll look into what I have. Only thing is I'm unsure of my cam.i think that my weber is actually smaller than I first thought.Mine is made by WILSON (made in spain) and has 26/on the primary side and 27/on the secondary side.so I'm assuming it's a 26/27.And it runs perfect :) Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted December 23, 2011 Report Share Posted December 23, 2011 I think EvanG ran a Weber about that size instead of the 32/36 off a Ford. PM him and ask what he finally used for jets. Quote Link to comment Share on other sites More sharing options...
Evan G Posted December 23, 2011 Report Share Posted December 23, 2011 28/36 I'm running 135 mains and 150 secs. 170 main air correction and 195 sec (i think) 50-55 idles Quote Link to comment Share on other sites More sharing options...
Scott123 Posted August 29, 2012 Report Share Posted August 29, 2012 How much off a power upgrade would a webber carby be on a 4k? And what are the costs involved? :) Cheers Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted August 29, 2012 Report Share Posted August 29, 2012 Definately noticeable, but not as good without a cam and exhaust to go with it... Its dirt cheap compared to other options. You need the carb, an air cleaner and an adapter plate, so a couple of hundred bucks. What options would you consider?? DCOEs, SUs, injection, twin stock Aisans?? Quote Link to comment Share on other sites More sharing options...
snot35 Posted August 30, 2012 Report Share Posted August 30, 2012 26/27 are the size of the chokes in a 32/36 from a 2lt ford from memory. If you look at the base of the carb it will probably say 32/36, looking down the throats will give you the 26/27 number. I'm happy with mine, but I never had a stock carb to compare too. It's a little grumpy to start, but not too much. It seems to go quite well with a shaved head. More mods would be better I think, we'll get to that. It's probably one of the best value intake mods around I reckon and adds tunability as you do more to the motor. Quote Link to comment Share on other sites More sharing options...
