jara Posted December 21, 2011 Report Share Posted December 21, 2011 Sorry for making my third thread so soon, but i'm not the most experienced and i learn a lot from here so here's the deal. In my engine bay theres this little tube thing that isnt hooked up to anything, i think it might be sucking air, what is it meant to be hooked up to? and what size hose will i need to buy when fixing it? thanks Quote Link to comment Share on other sites More sharing options...
FOOMAN Posted December 21, 2011 Report Share Posted December 21, 2011 (edited) I do believe that's where you run a hose to your charcoal canister (emissions crap). So no doubt someones ripped it out as they are useless. Not sure what size hose it is, mine just has whatever was on it cut short with a screw in it to block the hole off. Edited December 21, 2011 by FOOMAN Quote Link to comment Share on other sites More sharing options...
Trev Posted December 21, 2011 Report Share Posted December 21, 2011 As foo said, goes to the charcoal can. Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted December 21, 2011 Report Share Posted December 21, 2011 Does it matter if he leaves it or should he block it off? Quote Link to comment Share on other sites More sharing options...
Trev Posted December 22, 2011 Report Share Posted December 22, 2011 If it is sucking air then block it off. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted December 22, 2011 Report Share Posted December 22, 2011 Trim an inch off one of the other hoses and put it on with a screw glued in. Quote Link to comment Share on other sites More sharing options...
jara Posted December 22, 2011 Author Report Share Posted December 22, 2011 apparently charcoal cannisters help with fuel economy. is this true? is it worth chucking one in? if not i'll just do the 'screw in hose' idea Thanks guys Quote Link to comment Share on other sites More sharing options...
parrot Posted December 22, 2011 Report Share Posted December 22, 2011 No, it absorbs fuel vapours and as metioned is an important part of your vehicle emissions. If you get pulled over for a roadworthy check, it will lead to failure. There is absolutely no reason whatsoever not to have one. So pick one at random from your local wrecker and bolt it in. Quote Link to comment Share on other sites More sharing options...
7shades Posted December 22, 2011 Report Share Posted December 22, 2011 Quote Link to comment Share on other sites More sharing options...
Sloth Posted December 26, 2011 Report Share Posted December 26, 2011 Valid opinion... though I thought the standard approach of all Corolla owners was: Step 1: Remove emissions stuff Step 2: ?????? Step 3: Profit! No, it absorbs fuel vapours and as metioned is an important part of your vehicle emissions. If you get pulled over for a roadworthy check, it will lead to failure. There is absolutely no reason whatsoever not to have one. So pick one at random from your local wrecker and bolt it in. Quote Link to comment Share on other sites More sharing options...
