2Gr-Fe 3.5L V6 Ae86
ToySprinta
I bought it for $500 bucks with a stuffed engine and mags. Blew the 1st engine up, and beat around with another 4ac, even went to my 1st track day with it.
Now a 6 years later, it now has:
ENGINE
Toyota Aurion 2GR-FE
DRIVELINE
Custom Chromoly 3S-GTE Flywheel and clutch
W57
Locked Hilux diff
4.11
STEERING, SUSPENSION AND BRAKE
Front and rear whiteline swaybars, springs and shocks
Whiteline bushes
T3 Cambertops
T3 NRCA's
Whiteline tower brace
Custom rear strut brace/ harness mount
NP Wonder knuckles
Wilwood front brakes
S13 rear brakes
Whiteline Rear Traction Brackets
INTERIOR
from the front seats back - gone
Fibreglass fixed back bucket
Driver and passenger 4 point harness
Speco tacho
Autometer guages
Bond's 6-point cage
EXTERIOR
VTX copy kit
Fibreglass vented bonnet
TRD ducktail
Pics of motor going in :)
How it looks now :)
I've fitted a cage, Willwoods, modded the sump and made up some headers :)
These should help me stop nicely
Modded the sump to fit :)
Got some new knuckles for more lock :)
OLD281698_10150249779631439_36511661438_7499788_4413515_n.jpgNEW251478_10150249779591439_36511661438_7499787_4410631_n.jpg
Starting to feel the crunch now!
Its getting there though.
After trying out a few pipe designs, we figured that this layout wouldn't work:
This one would work a little better I think...
Putting theory into practice:
One side done!
Rinse and repeat for the other side! :)
Not too shabby at out first crack at headers in my mates tin shed :)
Yeah flat torque curve :)
http://youtu.be/BsK_1AVXZZY
Going for grip in this one
http://youtu.be/dMd6Mf4RxDI
My mate Grub checking out the grass
http://youtu.be/_vkQeyoa4zA
So had it at Powercruise on the weekend and foudn out that:
- In the wet, it'll happily smash limiter in 4th anywhere you like, and almost pull fifth around turn 12
- In the dry, it runs out of revs in third and the RPM drop to fourth means I have to straighten up before I can get enough speed to turn 4th sideways... damn fast though
We're going to lift the limiter to 8000rpm to see what she'll do
http://youtu.be/NNw0FPhcJhs
Edited by Stevumi
I'm currently working in Sydney, so it'll be out and about there :)
Upcoming events will be:
Motorkhana in Canberra on the 18th
Heading to Raleigh drift comp on the 1st
Then the next weekend is Toynats in Dubbo and hopefully the IDA day in Wakefield on Monday
...this is all pending whether I can string enough cash and rubber together :P
