BUZ440 Posted April 16, 2015 Report Share Posted April 16, 2015 800kg to 1100kg N/A x 4 A/A x 2.75 From VSB14 Talk to an engineer as always Quote Link to comment Share on other sites More sharing options...
japlish Posted April 16, 2015 Report Share Posted April 16, 2015 hence why I'm building a turbo 2rzfe :) = 2.4L Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted April 16, 2015 Report Share Posted April 16, 2015 3rz turbo would be legal in a ke70 under the new rules, should happen more often imo. As for the hilux diff, you use the whole thing, not just the centre. A really early rn20 diff is similar length to a ke70, but are very hard to track down, and are also known to have weaker axles than the later versions. If $$$ is not a big issuer probably better off shortening a later model one really, the later one is also more likely to come with the gearing you would need. Quote Link to comment Share on other sites More sharing options...
japlish Posted April 17, 2015 Report Share Posted April 17, 2015 no it wont be, 940kg (ke70) x 2.7 = max turbo cap = 2538cc Quote Link to comment Share on other sites More sharing options...
Bueno Posted April 17, 2015 Report Share Posted April 17, 2015 Ive been thinking about this also. I believe it comes down to this: If the ke70 weighs more than 1000kg it will be 1000ccx2.75 and 2.7L turbo is ok, if the ke70 weighs less than 1000 kg (like 900 you end up with 2.475 turbo). As we know there are many different luxury levels and options available within a single model so what Id like to know is this. Is there an accepted weight that everyone goes by or is an individual thing where you engineer makes you go to weigh station and check it? If so, Ill just be borrowing a bunch of tractor weights from the farmer next door and heading to the nearest scales to get my 1200 car checked. It would be nice if you can just go off the weight of the heaviest possible fully optioned ke70 :) As old mate Buz said above, I think we needs to talk to some engineers to get the good word on this. Jes Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted April 17, 2015 Report Share Posted April 17, 2015 Other thing to bare in mind is having an engine like that will need a fairly chunky gearbox and diff....which will as weight. Would this get you over the line if you were a bit under the 1000kg you need to fit the engine legally? Quote Link to comment Share on other sites More sharing options...
Bueno Posted April 17, 2015 Report Share Posted April 17, 2015 That could work too, I guess it depends if they refer to the original vehicle weight or the new vehicle weight when its finished. Jes Quote Link to comment Share on other sites More sharing options...
Bueno Posted April 17, 2015 Report Share Posted April 17, 2015 Ok so looked this up, it refers to the original vehicle mass so fitting heaver motor and box to bring up the vehicle weight isnt going to work. The information i have relates to QLD so is probably not correct for other states http://www.tmr.qld.gov.au/~/media/Safety/Vehicle%20standards%20and%20modifications/Vehicle%20modifications/Light%20vehicle%20modifications/NCOP/4sectionlaengine.pdf " 2.13.1 Vehicle Mass The mass of the vehicle referred to in Tables LA1, LA2 and LA3 is the original (unmodified) tare mass of the model vehicle fitted with the largest engine available for the model in Australia but without optional accessories (air conditioning, tow bars etc.). The mass of the vehicle, whether it is a sedan, station wagon, utility, etc., should be based on the heaviest sedan version of the model (not station wagon version) sold in Australia." Now to find out what the heaviest "factory" Australian ke70 corolla sedan with standard accessories . Jes Quote Link to comment Share on other sites More sharing options...
BUZ440 Posted April 17, 2015 Report Share Posted April 17, 2015 Engineers refer to the VSB14 which is what was made effective in QLD from November 2012, TMR does say one thing, but you need an engineer to sign it off, it's not based on the most weight you can get out of it, there is a booklet of the weight of all cars they start the calculation 3RZ with a turbo will cause she development issues as you go, head bolts, sump and ancillaries, Go a 1J, kits are available and plenty of support, if you have the money buy luke coys 8 sec ke10 in the for sale section Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted April 18, 2015 Report Share Posted April 18, 2015 I sell bolt in 3RZ to KE70 kits, no firewall/tunnel mods Quote Link to comment Share on other sites More sharing options...
japlish Posted April 21, 2015 Report Share Posted April 21, 2015 R150 gearbox fits in a ke70/ae86 tunnel too Quote Link to comment Share on other sites More sharing options...
Bueno Posted April 25, 2015 Report Share Posted April 25, 2015 So I looked at a 3RZ with motor, box, ecu and wiring, tailshaft and radiator this morning at 10, 2 hrs later its on my trailer heading home..... Quote Link to comment Share on other sites More sharing options...
BUZ440 Posted April 25, 2015 Report Share Posted April 25, 2015 So I looked at a 3RZ with motor, box, ecu and wiring, tailshaft and radiator this morning at 10, 2 hrs later its on my trailer heading home..... Cool, have you spoken to an engineer tho? Quote Link to comment Share on other sites More sharing options...
Bueno Posted April 25, 2015 Report Share Posted April 25, 2015 No, real men go off half cocked then have to do stuff twice and sell other stuff at a loss :) . Its going to be NA so falls inside capacity guidelines. Jes Quote Link to comment Share on other sites More sharing options...
Rollav6 Posted April 25, 2015 Report Share Posted April 25, 2015 Would a 2tr-Fe be a similar job? Quote Link to comment Share on other sites More sharing options...
