Sign in to follow this
RhysE
Help!! Stereo Stopped Working
hi guys i was installing my sub today in the boot of my ke70 and during the installing sometime my radio
fuse blew and i dunno why, and now even after the fuse has been changed the stereo wont work?
i didnt do the wiring the previous owner did and there is a scotch clip clipped to 1 wire with 2 red wires coming out
and 1 goes to the stereo but the other is just hanging there looked like it was connected to maybe a brown wire not sure
cause i can't find any brown wires.
SOMEBODY HELP! i need to get my stereo to work for my cruise to wisemans ferry tomoro lol
cheers guys
Share this post
Link to post
Share on other sites
I found 1 ground that goes from nowhere to a bolt but can't see where it should.be the stereo was working fine before I started running my sub stuff
Share this post
Link to post
How do I fix that? I've found 1 other ground wire that goes to.nothing 1 end its bolted the other end not ?
Share this post
Link to post
also the 5amp radio fuse blew, do i need to replace that with a 5 amp or will a 10amp work at all ?
cheers
Share this post
Link to post
Well if your ground wire is connected to the chassis and not to the stereo it won't work, and a 10 amp will be fine.
Share this post
Link to post
rewiring would be the best option providing you isolate the original problem that resulted in the short (usually positive coming into contact with an earth source of some sort) and as for the fuse it would be unwise to use a larger fuse as this may result in more problems than it is worth! I have seen dash wiring that has been fried due to the use of larger fuse's
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
