MoNsTaR Posted August 29, 2012 Report Share Posted August 29, 2012 hey guys, Ive been thinking about doing a 1c turbo conversion for my ke70 for something different, I figured i could probably pick one up fron nz for close to nothing or japan even, I wanted to know what else would i need to do it, could i use the standard tank, what fuel pump do i need, things like that, I'm an engine reco so messing with the engine is not any problem. I'm keen to get this up and running, just would like some info before i jump in. thank you Quote Link to comment Share on other sites More sharing options...
ke70dave Posted August 29, 2012 Report Share Posted August 29, 2012 I am seeing alot of "japan only" on the toyota C engine wiki. I would be weary of putting in an ancient diesel engine into a car you can't easily get parts for. Quote Link to comment Share on other sites More sharing options...
Jono.C Posted August 29, 2012 Report Share Posted August 29, 2012 This "close to nothing" idea from japan is out straight away. Over $100 in fee's to get a $50 gauge cluster here.. Quote Link to comment Share on other sites More sharing options...
19914afc Posted August 29, 2012 Report Share Posted August 29, 2012 I'd rather put in a newer diesel, 1kd are ok engine, make decent tourque but if you wanted a boat anchor may as well go an old 350 chev for the cheaper. Quote Link to comment Share on other sites More sharing options...
Willis Posted August 29, 2012 Report Share Posted August 29, 2012 but if you wanted a boat anchor may as well leave the 4K in it. Quote Link to comment Share on other sites More sharing options...
MoNsTaR Posted August 30, 2012 Author Report Share Posted August 30, 2012 the idea was to get the engine from NZ rather then japan, as my misses family are all kiwis it would be a more viable option. i pretty much wanted to mess around with an engine that came in the *e7* that no one messes with, figured it would be goof for a laugh, I'm still keen on the idea, just need more imput. i guess if i can't have a 1c, any toyota diesel will do :P Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted September 8, 2012 Report Share Posted September 8, 2012 (edited) The 1 C powered and rarely mentioned CE70 is a cool car. Its a shame we didn't get it here in Australia. Perhaps a nice mesh of old/new would be a 2c from a later CE9X corolla fitted to the ke70. Its not that bad an idea, they came with the superior supra W5X series gearbox from what I have seen and they share a bell housing pattern with an S engine, so if you get bored with the diesel you can fit a 3s or 5s to the car easy enough. The front end panels were a bit different too at least on the wagons Ive seen. Edited September 8, 2012 by LittleRedSpirit Quote Link to comment Share on other sites More sharing options...
19914afc Posted September 8, 2012 Report Share Posted September 8, 2012 Funnily enough for some reason at work we have a repair manual for a 1C and the CE70 corolla for some odd reason. Quote Link to comment Share on other sites More sharing options...
TheHeadShaver noob Posted September 10, 2012 Report Share Posted September 10, 2012 its a easy enough swap, i have a 1c laying outside, it has a w50 gearbox with a original C bellhousing, this engine is from a 1983 or so carina diesel. u can use the same tank but u need a return line for the fuel and u need the 1c alternator with the vacuum pump for the brakebooster, but thats about it as far as i can remember. For gearbox i been told u can use the gearbox for the S engines, but i never tried this myself so i can't confirm this is true. But be aware, the 1c's is a hella lazy engine, a 4k is like a ferrari compared to the 1c, of course it helps if u turbo it, but i don't think this engine will ever be a fun ride. they run very economic tho, i been thinking about doing this swap myself, just for the economic reason. If u first wanna do a swap like this, go for 2ct or 3ct, 2ct is supposed to be the better quality engine outa them two and it runs semi decent. Quote Link to comment Share on other sites More sharing options...
19914afc Posted September 11, 2012 Report Share Posted September 11, 2012 My 3t that was in my T18 went really good for what it was, just put a bigger carb on and exhaust and could get it going quite well. Quote Link to comment Share on other sites More sharing options...
flyinwall Posted September 13, 2012 Report Share Posted September 13, 2012 My 3t that was in my T18 went really good for what it was, just put a bigger carb on and exhaust and could get it going quite well. they are talking about the 1C,2C,3C diesel motors NOT the 2T,3T petrol motors Quote Link to comment Share on other sites More sharing options...
CE70 Posted September 18, 2012 Report Share Posted September 18, 2012 A very common swap in our part of the world. 2C-T was more popular. Those used to come from Liteace/Towance/Carina/Corona and the lot. T50 gearbox also works. For an even torque delivery, change the diff as well, otherwise standard diff also works fine on highways and straighter runs. Used to have one, check my nick :) Quote Link to comment Share on other sites More sharing options...
Stig53 Posted November 10, 2012 Report Share Posted November 10, 2012 Diesel motor options, a V9X Nissan/Renault V6 3.0 TDI is something I considered.. Might be interesting. Quote Link to comment Share on other sites More sharing options...
