B.L.Z.BUB Posted September 19, 2012 Report Share Posted September 19, 2012 (edited) This is ONE way of doing it, and as usual its quick, cheap and easy. Needed: NE/NF/NG Pajero master cylinder. Old Mazda master cylinder banjo fittings. The short one was from a 626 and the longer ones were from a 121 (I think), both FWD. I used the longer of the three. I ripped them off one in a wrecker for nothing, remember to keep the washers. So rip out the old KE70 master, as you can see the outlets are in completely different configurations. Bolt the Pajero one in. Here you will see the issue with the brake lines in relation to the outlets. Yes you could make up new brake lines. Looking at the gap between the master rear outlet and the 4AGE plenum it looks like it would be a tight fit possibly meaning the plenum would hit the brake line. Front line Rear line This is where the banjo joints come in, I used the shorter one on the rear brake line and the longer one the front brake line. For some reason the bolt hole for the front line is shallower than the other so I needed to use an extra washer. Total time to install about 20 minutes. Total cost around $80 EDIT: don't know why the images are all over the place :/ Edited September 19, 2012 by B.L.Z.BUB 2 Quote Link to comment Share on other sites More sharing options...
HAIGHIE Posted September 19, 2012 Report Share Posted September 19, 2012 (edited) is this only needed if the brakes are upgraded or would this be a brake upgrade in it's self for just the stock ke70 brake? looks neat, tidys up the old super long and ugly master cylinder Edited September 19, 2012 by HAIGHIE Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted September 19, 2012 Author Report Share Posted September 19, 2012 (edited) Only good with a brake upgrade. Edited September 19, 2012 by B.L.Z.BUB Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 19, 2012 Report Share Posted September 19, 2012 Nice work- I love cheap & easy! Higher pedal? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted September 19, 2012 Author Report Share Posted September 19, 2012 From what I've read it will be but I like that, makes toe heel easier. I may need to purchase a brake bias adjuster for the rear but will wait and see how the balance feels. Or upgrade to discs on the rear. Quote Link to comment Share on other sites More sharing options...
cicca_294 Posted September 20, 2012 Report Share Posted September 20, 2012 is this only needed if the brakes are upgraded or would this be a brake upgrade in it's self for just the stock ke70 brake? looks neat, tidys up the old super long and ugly master cylinder i had one in a stock keto, and since one in a keto jap 86 brake setup. Decent upgrade for both setups. Quote Link to comment Share on other sites More sharing options...
HAIGHIE Posted September 21, 2012 Report Share Posted September 21, 2012 (edited) i had one in a stock keto, and since one in a keto jap 86 brake setup. Decent upgrade for both setups. arh kool might do it knowing it aorks with stock brakes, even if it was just to tidy up the look abit, an then i gess it also allows to upgrade the brakes later aswell cheers mate. good write up aswell B.L.Z.BUB Edited September 21, 2012 by HAIGHIE Quote Link to comment Share on other sites More sharing options...
86Ali Posted March 18, 2013 Report Share Posted March 18, 2013 From what I've read it will be but I like that, makes toe heel easier. I may need to purchase a brake bias adjuster for the rear but will wait and see how the balance feels. Or upgrade to discs on the rear. Did you need the brake bias adjuster for the rear? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted March 19, 2013 Author Report Share Posted March 19, 2013 Nope. Brakes work fine. I'm taking it for a workout this weekend so if there are issues I'll III update Quote Link to comment Share on other sites More sharing options...
86Ali Posted March 19, 2013 Report Share Posted March 19, 2013 What is your brake combo? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted March 19, 2013 Author Report Share Posted March 19, 2013 Corona twin pot sumitomos and corona slotted rotors. Quote Link to comment Share on other sites More sharing options...
86Ali Posted March 19, 2013 Report Share Posted March 19, 2013 (edited) I take it they're Xt130 Corona? I'm running Xt130 strut based coilovers with modified caliper bracket to take bigger MA61 vented hubs and brakes. I am keen to hear reports. Edited March 19, 2013 by 86Ali Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 24, 2013 Author Report Share Posted May 24, 2013 Just a bump to say I've been running this set up for months now. Pedal feels stock, plenty of anchors when needed. A truly awesome cheap upgrade. Quote Link to comment Share on other sites More sharing options...
yohan18 Posted November 24, 2013 Report Share Posted November 24, 2013 Just checking is that $80 for just the master cylinder or would that be including the banjo fittings as well if bought from the wreckers? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted November 24, 2013 Author Report Share Posted November 24, 2013 I didnt pay for the banjo fittings. If it fits in your pocket its free at the wreckers. Quote Link to comment Share on other sites More sharing options...
