Hello everyone
I couldn't find my answer anywhere so I was wondering if you could help me out.
Assuming the motors are both 4afe could I take parts from a ae92 and use it on ae94.
Primarily, brake rotors and pads? I can't find many ae94 rotors but 92 are plentiful.
Thanks!
ae9x mechanical items are interchangable,
but brake rotors and brake pads do vary across the ae9x range.
best way is to check the build plate on the car as it will give you a build date, and a parts interpreter may be able to order you the right parts.
or do it the old fashion way and measure the rotors diameter, and take a rubbing of the brake pad, then you check again online image and specs
