Jordanrw 0 Report post Posted February 14, 2013 Hi, I own a 1980 Toyota Corona xt130 wagon (xt131?). It has 108000 kms on the clock and is running of a crappy 1.9L Holden Starfire engine. It was my first car and I didn't know what a nightmare the engine would be. Anyway, recently I have been having some issues with it. While driving the car will sometimes randomly start jolting pretty violently and to stop it I apply the clutch. In extreme cases it will continue as i slow and change down gears until it eventually stalls. After letting it sit for a while it usually works fine. The first times this happened it was going up hill at medium speeds (60 & 80 km/h) but now it has happened on straights after a while of driving. I replaced the fuel filter, but this didn't really help. I was thinking it could be something wrong with the carb or fuel pump as it seems to be a starvation issue but I am no mechanic so I don't know! Also it has no fan shroud if that would make much of a difference (vapour lock?) Any help on this would be greatly appreciated! Still love it's looks though, old toyotas are the greatest. Cheers, Jordan. Quote Share this post Link to post Share on other sites
Jordanrw 0 Report post Posted February 14, 2013 Also, it can take ages to start up in the mornings, especially if it is cold. Quote Share this post Link to post Share on other sites
Tazrolla 0 Report post Posted February 14, 2013 Does sound.like a fuel issue.. try putting some throtle body cleaner through the carby... I had simular prob with my hilux recently and that just ended up being a blocked fuel filter. But you already changed that Quote Share this post Link to post Share on other sites
Rgordon93 0 Report post Posted March 18, 2013 You might have to change all the fuel lines, and get a new fuel pump, I did it to my RT80 and the amount of shit that was clogged up through the fule lines was crazy she runs like a dream now :) Quote Share this post Link to post Share on other sites
altezzaclub 272 Report post Posted March 19, 2013 Measure the fuel flow at the carb- just run it into a coke bottle and time it for L/min. 1.5L/min feeds twin DCOE Webers on a 2L 18RG, so somewhat less than that would be fine. The strip the carb and remove the jets & wash everything out with petrol pumped through a syringe. Then pump petrol through all the drillings in the carb. ..or just take it to a carb place and have them strip & clean it. Not starting cold sounds like a lack of richness for sure. hmmm... my old man had a leaf in the fuel tank that would randomly get sucked over the outlet and starve it. When the motor died and the car stopped the leaf would float away without the suction to hold it on.. What was the old fuel filter like inside? Quote Share this post Link to post Share on other sites
