Sign in to follow this
harryrolla
Head Unit Not Putting Sound Through ?
Check the terminals at the speakers.
Check that you have wired it to the head unit correctly. (Double check you have the right diagram to work with)
EDIT - Good trick to use to check your wiring is correct to the speakers and the speaker cable isn't completely broken is with a AA battery.
Edited by B-Lugg
Share this post
Link to post
Share on other sites
EDIT - Good trick to use to check your wiring is correct to the speakers and the speaker cable is completely broken is with a AA battery.
I'm sure it's a good trick, but how do you do it...
Share this post
Link to post
put the speaker wires on the battery ends, doesnt matter if its + to +, it makes the speaker click, good trick when you lose track of which speaker wire is which.
Share this post
Link to post
What he said...
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
