Valve Lash
NZ_KE20
My Crow cam came with 16thou specs, and as you've found it was very noisy. I'm running 10 & 12 now, I don't think it is really crucial unless you're racing the car and the gap can be used to adjust the cam timing then, so long as there is a gap when its hot.
One tappet is still noisy, I'm sure the rocker is worn away to a groove, its impossible to find without stripping it.
