Jordanrolla Posted January 28, 2014 Author Report Share Posted January 28, 2014 1JZ into KE70 kits added Quote Link to comment Share on other sites More sharing options...
odd_shogun Posted February 3, 2014 Report Share Posted February 3, 2014 (edited) Would the ke70 sr20 swap kit fit the U.S. te72/ae71 corollas? as the steering is on otherside will i have a problem with clearance? Edited February 3, 2014 by odd_shogun Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 3, 2014 Author Report Share Posted February 3, 2014 te72 would use steering box and t series engine mounts? I sell kits to suit ae71, i couldnt say if it will clear as ive never seen a lhd setup. But as always, exhaust is easier to modify than intake if it doesnt fit. Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 14, 2014 Author Report Share Posted February 14, 2014 Dirty old bogandore V6 + T5 into KE70 kits added to the list Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 18, 2014 Author Report Share Posted February 18, 2014 1JZ/2JZ into KE30 kits added Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 19, 2014 Author Report Share Posted February 19, 2014 3SGTE into KE20 series added Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 23, 2014 Author Report Share Posted February 23, 2014 SR20 into KE20 kits added Quote Link to comment Share on other sites More sharing options...
DavidKe20 Posted February 23, 2014 Report Share Posted February 23, 2014 (edited) Hey mate I see you have got sr20 to ke20 kits. How do I go to purchasing them? Thanks Edited February 23, 2014 by DavidKe20 Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted February 23, 2014 Author Report Share Posted February 23, 2014 best to send me a pm mate Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted March 2, 2014 Author Report Share Posted March 2, 2014 4AGE into KE10 kits added (finally) Quote Link to comment Share on other sites More sharing options...
drogs Posted March 6, 2014 Report Share Posted March 6, 2014 Any more info on the 4AGE into ke10 kits ? Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted March 6, 2014 Author Report Share Posted March 6, 2014 first page, first post. Will be working out a hydraulic pedal box kit for it also which uses a howe type throw out bearing to fix the slave cylinder issue and relocates the brake master to get around the bigport inlet manifold issue. Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted March 10, 2014 Author Report Share Posted March 10, 2014 3RZ into KE70 kits added Quote Link to comment Share on other sites More sharing options...
kickn5k Posted March 16, 2014 Report Share Posted March 16, 2014 first page, first post. Will be working out a hydraulic pedal box kit for it also which uses a howe type throw out bearing to fix the slave cylinder issue and relocates the brake master to get around the bigport inlet manifold issue. Could/would this work with std style brake master.? Just looking at my K-T setup ATM. If so would it be a change over type thing or mod our pedal boxes? Quote Link to comment Share on other sites More sharing options...
Jordanrolla Posted March 16, 2014 Author Report Share Posted March 16, 2014 I don't understand your question. 4age into ke10, bigport manifold does not clear brake master, smallport manifold may fit but i havent had confirmation yet. If you want to run a bigport with bigport manifold when i get around to designing the pedal box kits i will design 2 versions. 1st to relocate the brake master so to clear the bigport manifold, 2nd will be just a hydraulic clutch conversion type for people who use smallport or go quads or even custom intake manifold. Quote Link to comment Share on other sites More sharing options...
