V8Pnut Posted October 3, 2013 Report Share Posted October 3, 2013 Hi guys, hope you can help. My daughter has an AE92 Seca 1989 and was having problems with both front seat belts not unlocking from the retracted position making impossible to put the belts on. I bought 2 good second hand ones and now the drivers belt is acting up again. It worked OK for a couple of days and now not. What do you suggest? Are the belts specific to left and right hand side? Quote Link to comment Share on other sites More sharing options...
corollaparts69 Posted October 6, 2013 Report Share Posted October 6, 2013 Hello, it sounds like either your very unlucky with seatbelts or they are fitted incorrectly(which is impossible to do in a seca).If the retracting mechanism is not at the correct angle/position,it will keep locking up(try unrolling a seatbelt when it's not fitted to a car,bloody hard to do,unless held in the right position). Having said that,I can't see how it could be incorrectly fitted to a seca...they only bolt in one way. I believe the seatbelts are strictly left and right but I haven't tested the theory. If you want to try your luck on another second hand set,I have a set of front and rear seatbelts with bolts from a seca for $20 set. Located at Dinmore,near brisbane qld. Other seca bits available....rear louvre...door windvisors/weathershields...rear bumper...tail lights etc. PM me if your interested. Thank you...skip. Quote Link to comment Share on other sites More sharing options...
AE93_Seca Posted November 2, 2013 Report Share Posted November 2, 2013 might be worth a shot, silicon spray works wonders on seatbelts, fixed up mine with a few quick sprays-might be worth a it considering a can is like $10 from supershit... Quote Link to comment Share on other sites More sharing options...
terryo Posted November 13, 2013 Report Share Posted November 13, 2013 (edited) they are definitely left & right sided. the locking ratchet goes one side only. i can usually get them re-webbed and repaired (and re-certified) thru work. as a professional mechanic, i would never fit a used belt due to risks of not working correctly. as a private home repairer you might be happy with that risk Edited November 13, 2013 by terryo Quote Link to comment Share on other sites More sharing options...
