Jordanrolla
Ke20 Ke30 Ke55 Ke70 Ae71 And Mx83 Cressida Hydraulic Pedal Box Kits
Hi all, Jordan from KE conversions
I am currently converting KE series corolla cable pedal box's to a hydraulic setup.
All my pedal box's are done on an exchange basis for your old pedal box. I can modify AUTO or MANUAL pedal box's. Please let me know what pedal box you are sending me. If you have a AUTO pedal box you need to send me the brake pedal so I can replace the pedal to suit a manual setup.
KE20
Modified pedal box, braced plate on box for minimal firewall flex
6mm clutch pedal, replaces the 4.5mm stock one
New clutch master cylinder
Braided Teflon line to suit your application
New slave cylinder to suit your application.
Firewall marker to accurately drill out your firewall
Price $325 on exchange for your AUTO or MANUAL pedal box
KE30 KE55
Modified pedal box
New clutch slave cylinder to suit your application
Price is:
$275 on exchange for a MANUAL pedal box or
$325 on exchange for a AUTO pedal box
KE70 AE71
Price is $325 on exchange for your MANUAL or AUTO pedal box
Edited by Jordanrolla
  • Upvote 1
Share this post
Link to post
Share on other sites
Custom manual pedal box kit to suit MX83 Cressida
As most of you are aware, MX83 Cressida never came out manual. There are alternative's but nothing to my knowledge is a direct bolt in. Commonly the MA70 pedal box is used but requires some modification to fit, is a bit of a pain to mod and is not always a neat fit. Usually a cut here, notching holes there and weld something over there.
So I designed this to be as simple as possible, 100% bolt in, no cutting, drilling or welding anything.
The pedal box itself is 3mm mild steel plate and is tig welded.
A 6mm clutch pedal
and a ST185 celica clutch master cylinder included.
Included :
Pedal box
Clutch pedal
Clutch master cylinder
Brake pedal with manual pedal welded on
bolts for clutch pedal and master cylinder
Price is $250
The manual brake pedal is on an exchange basis, If you want my pedal sent out first I will require a $50 core deposit so I can continue to provide brake pedals for the next person. You will be refunded $50 once I receive your brake pedal.
Currently I can include the Teflon and metal bush for the clutch pedal but I have a limited supply of these until I go for a wrecker run
Only thing that wont be included is the connecting pin for the master cylinder to clutch pedal.
Share this post
Link to post
