focus218 Posted November 7, 2013 Report Share Posted November 7, 2013 I have a Toyota Kp36 PickUp Truck wich I am really proud about http://imgur.com/a/3rRfs#0 :) The power I get is very low and I want to do an engine conversion but I don't know what engine will fit without any chassis conversion. The other thing is that because I live in a small country (Cyprus) not many option are available regarding the engines availability. So I was thinking about installing a Weber kit I found online but I don't know if I will need any other changes on the 2K engine, http://www.ebay.com.au/itm/330762578476?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 If you can give all the options available I would really appreciate it. Quote Link to comment Share on other sites More sharing options...
Mechanical Sympathy Posted November 7, 2013 Report Share Posted November 7, 2013 Ooh so many choices. Easiest (i.e. closest thing to a bolt-in swap) would be a 5K or a 7K. From there, the sky and your budget are truly the limit! Quote Link to comment Share on other sites More sharing options...
Bowler Posted November 7, 2013 Report Share Posted November 7, 2013 Did Cyprus get the townace/liteace? or carina? They'll be your best bets fo sourcing a 5k/7k (7k might require sump alterations to fit) Quote Link to comment Share on other sites More sharing options...
focus218 Posted November 7, 2013 Author Report Share Posted November 7, 2013 Did Cyprus get the townace/liteace? or carina? They'll be your best bets fo sourcing a 5k/7k (7k might require sump alterations to fit) We got both townace and liteace. Do those engines fit my KP36? Which manufacturing year should I search? Thanks .... Quote Link to comment Share on other sites More sharing options...
focus218 Posted November 7, 2013 Author Report Share Posted November 7, 2013 Ooh so many choices. Easiest (i.e. closest thing to a bolt-in swap) would be a 5K or a 7K. From there, the sky and your budget are truly the limit! Will I be able to install the Weber kit I found online without any in-depth engine modifications on my 2K? Quote Link to comment Share on other sites More sharing options...
Mechanical Sympathy Posted November 7, 2013 Report Share Posted November 7, 2013 (edited) Weber and manifold combination ought to be interchangeable with whatever K series engine you end up using. But I've never seen a 2K so I don't know if it has any extra water inlets/outlets to the manifold that later engines don't have but I'm sure it could be blocked off. Sometimes manifold flange thicknesses don't match but easily fixed. Not major modifications. The Liteace 5K was 1.5 litre models from the mid-late 80's onward. The Townace 7K was 1.8 litre models from around 1997 onward. Edited November 7, 2013 by Mechanical Sympathy Quote Link to comment Share on other sites More sharing options...
bruce Posted November 7, 2013 Report Share Posted November 7, 2013 There was a Publica in the rides section a while ago with a supercharged 7K: http://www.rollaclub.com/board/topic/5895-publica-1000-pick-up-7k-ze-76/ http://kotisivu.dnainternet.net/pekkola/timangi.html Quote Link to comment Share on other sites More sharing options...
