5ksev Posted November 28, 2013 Report Share Posted November 28, 2013 Hey all, I've recently rebuilt and installed an sr20det red top into a ke70.. It has disco potato turbo, 875cc injectors Bosch 044 fuel pump 3" cooler piping Haltech sprint 500 ecu Went to take it for a drive the other day, it started, ran & idled fine.. Would rev to 3G fine.. But as soon as you would hit or go over 3, it just shuts down! It feels as if it has no spark, but still pumping fuel.. If I keep my foot on the throttle, then take it off before it completely stalls.. It will back fire, cough & splutter then return to idle.. And if I just take my foot straight off, it returns to idle as if there were no problem? I've replaced rubber fuel hose as it had a very small split.. No difference, My iacv WAS NOT hooked up, or connected to water, so I completely removed it and used a blanking plate.. Idles better but still hasn't fixed my problem I do have spare coils, should I try changing them over? Also at 1000rpm ( idle ) I am only getting around "14" on the vacc gauge? Do I have a leak or can the 3" piping have something to do with that? NOTE! E85 Bosch 044 875cc injectors 3" piping NO IACV NO C02 sensor NO AIR FLOW SENSORS.. Computer was tuned for this setup when came out of donor car Quote Link to comment Share on other sites More sharing options...
ke70dave Posted November 29, 2013 Report Share Posted November 29, 2013 With that haltech on there and such a custom setup, I got no idea whats going on really. The only way your going to be able to find out is to connect a laptop to the ecu and see what it is doing and what its complaining about. Quote Link to comment Share on other sites More sharing options...
