Clapped out Posted April 2, 2014 Report Share Posted April 2, 2014 ^^^^^By looking at the vacuum secondaries, it appears the vacuum line is directly connected from the diaphragm to the secondary throat, my opinion it shouldn't be a problem if you fit to an earlier rolla, simply because there is no other way it is connected. I'd just block off any unnecessary lines on the carby with vacuum block off's. Oh and haven't forgotten about the jet sizes, cheers! Quote Link to comment Share on other sites More sharing options...
Clapped out Posted April 4, 2014 Report Share Posted April 4, 2014 okey doke, finally sussed out the jet sizes in the 5k stock carby, Primary was 106 secondary was 157 cheers! Quote Link to comment Share on other sites More sharing options...
GJM85 Posted April 4, 2014 Author Report Share Posted April 4, 2014 Wow. That primary is really quite small. Quote Link to comment Share on other sites More sharing options...
Clapped out Posted April 4, 2014 Report Share Posted April 4, 2014 Yeah I was quite surprised myself, minor things are different in uncommon ways with the carby, if your ever up this way, pop in and have a look if ya want, cheers! Quote Link to comment Share on other sites More sharing options...
Andy43 Posted May 5, 2014 Report Share Posted May 5, 2014 There are many variations of the 3k carby venturi size. 19,21mm were common Pri sizes 24,25mm were common Sec sizes All were mech secondary’s with a air valve in the sec venturi. The 3kb had different sizes again sorry I cannot recall the sizes. Interesting early 3k carbys all have 21mm pri and 24 mm sec and have smaller 6mm throttle shafts and later ones run 8mm shaft. Dyno shows no difference between the 24mm sec and the 25mm sec. Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted May 5, 2014 Report Share Posted May 5, 2014 So I've got my twin Aisans running well but cannot get new air filters that fit! Any solutions other than changing the housing (not changing it!) or getting custom filters made?? Quote Link to comment Share on other sites More sharing options...
coln72 Posted May 5, 2014 Report Share Posted May 5, 2014 I cut the bases out of a couple of single carb air cleaners and welded those into ( onto) a pair of chrome air cleaners meant for stromberg carbies. Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted May 5, 2014 Report Share Posted May 5, 2014 I have the genuine oval twin filter housing... not changing that, just can't find filters (2 x round or 1 x oval) to fit in it :( Quote Link to comment Share on other sites More sharing options...
coln72 Posted May 5, 2014 Report Share Posted May 5, 2014 When I had the original air cleaner, I used to get the oval element from toyota. This was 20 odd year ago though. Sorta making me feel old :( Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted May 5, 2014 Report Share Posted May 5, 2014 Thanks Coln. I couldn't find the oval filter but I did find the part number for the original round filters! Even found a pair up for auction on Ebay. Quote Link to comment Share on other sites More sharing options...
coln72 Posted May 5, 2014 Report Share Posted May 5, 2014 My bad, had the twin round ones too. Used to get those from Toyota Quote Link to comment Share on other sites More sharing options...
airocobra Posted May 5, 2014 Report Share Posted May 5, 2014 Pretty sure UNI FILTER will make any size you want if it is not in there std range , but for a price of course. They may have something in there catalogue that may fit from there bike , quad or rally filter range . . Quote Link to comment Share on other sites More sharing options...
Andy43 Posted May 10, 2014 Report Share Posted May 10, 2014 K&N have a handy little find section on their website you just enter the size you need and presto it finds what you need Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted May 11, 2014 Report Share Posted May 11, 2014 Thanks Andy, I tried that already and they don't make these (except custom). From what I found only Toyota make this size and they are not stocked anywhere any more. Part number is 17801-24020, a few people had stock for sale on Ebay and you can order them in from Japan :) Quote Link to comment Share on other sites More sharing options...
megamannz123 Posted July 3, 2014 Report Share Posted July 3, 2014 How did you end up going with the twin carb jetting? I have a worked 5K just about finished and will be fitting twin Asian carbs I think they are off a 3KB from what I can see everything is the same size on both. Any advice for set up? Quote Link to comment Share on other sites More sharing options...
