My Starlet Kp61
Chingy
Where did you get the flywheel? And how much was it if you don't mind me asking?
The flywheel is made by Jun in Japan, I got this through a company in New Zealand that deal direct with Jun, I paid I think around £300 to £400 with taxes and shipping but I have seen them as much as $900!! Hope this helps
Nice build, so i imagine you need to deck the head along with those pistons to get 11:1?
Thank you, yes head had been decked to up the compression. Now researching cams.
Looking at an Auckland Cams #566 profile which is a Wade 140 grind
Advertised duration: 290 degrees
Duration @.050”: 239 degrees
Cam lift: ..296”
LCA: 107 degrees
Open to suggestions.
Basic engine spec
Toyota 4k over bored by 60 thou to 1344cc
Compression raised to 11:1
Ported & Flowed head, valve seat job etc
Twin 40dcoe carbs
Car is used for occasion fast road use
  • 2 months later...
