Sign in to follow this
jlove14
Sub Woofer Without Replacing Head Unit
hey guys i am a complete newbie here and have a 2012 Corolla Ascent hatch australian model that is right hand drive and have the steering wheel controls for audio and radio stations, but my question is does the default head unit that i know is used in many cars have a sub out so when i go to fit a 12 inch kicker sub i don't have to bother installing a new head unit and only have to bother with an amp and the sub
any help with this would be appreciated
Share this post
Link to post
Share on other sites
You'll need an amp to power your sub woofer either way though. Head unit wont have the grunt to run it.
Some (most?) amplifiers will take a speaker input, so if you don't have any RCA ports on your stereo you can splice into your rear speaker wires connect them up to your amp and then connect sub woofer to amp too.
If its an oem stereo i think its highly unlikely you will have RCA plugs on the back.
Share this post
Link to post
Factory CD players don't have RCA outputs so don't worry about taking it out to check.
Use a Line Out Converter such as the Aerpro APHL2 to convert the rear speaker signals to RCA leads for your amplifier (preserving the rear speakers too,) or buy an amplifier with High Level Inputs.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
