Sign in to follow this
Ke20peanut
Fs: 1973 Ke20 Corolla Yellow 3T Gold Coast
For Sale: 1973 ke20 toyota corolla
Ford rapid yellow respray
Full QLD rego to August 2015
Car loacted on the Gold Coast, QLD
Engine:
3T 1.8L stroked to 1900cc motor
Twin Weber 40mm DCOE jetted and tuned to suit current set up
Revs to 7000rpm
Electronic distributor (no points or condenser)
Hi volume low pressure adjustable fuel pump set at 3psi currently
New water pump
New spark plugs
TRD camshaft
T50 5 speed gearbox
new exedy clutch kit
7.5kg flywheel
Upgraded toyota 90amp alternator
All engine, gearbox, diff oils changed and flushed recently
Suspension and brakes:
4 wheel disc brake
4.4 ratio LSD - reinforced differential.
New wheel bearings
New brake lines and pads
Reinforced and boxed LCA's
New Tilton brake master cylinder
Hydraulic handbrake + factory handbrake
Speedway adjustable brake bias in cabin control knob
New tailshaft uni joints
Chassis:
Straight car
No rust
6 point bolt in roll cage with offset fire deterrent rubber pads
Seam welded for extra strength at usual weak point areas
Home made front strut tower bar
Fender flares
New tailights
Monza reclinable bucket seats
OMP 3 point racing harness
Fire extinguisher mounted on roll cage
Complete badges (with extras included)
New boot rubber seal and front windscreen rubber seal (fits original chrome trim)
Retractable seat belts upgraded to comply with standards for mod plate application back in 1995.
Extras:
5" tachometer w/ shiftlight
Speco 52cm guages (volts, water temp, oil temp)
Battery kill switch on dash
6000k HID Hi/Lo H4 kit
Volk Racing 14x7" 2 piece mesh rims
New dunlop sport sp3000 tires 175/60r14
Hella driving fog lights mounted in front (removable-used original holes available on front bar so no extra holes)
12 month old battery (36 months warranty with receipt)
CTEK smart battery charging kit with quick connect ports installed so you can charge the battery safely without having to remove it from the vehicle. You can safely leave it on the charger for weeks at a time if you don't drive the car often but want to ensure a fully charged functioning battery without affecting its battery life.
All electronics and factory switches work
Goes very well
Driven hard but not abused with lots of money spent to maintain the car properly
Folder of receipts available
Mod plated for engine, gearbox, brakes, rollcage, 2 seater conversion, rear axle.
Completely street legal and is road registered
Will come with all supporting documents and Copy of QLD road legislations for hassle free driving
Yes, I have been pulled over by the police and have always been complimented on the car being modified properly according to specifications. Never had a problem with it.
Any inspection welcome
Can sell with RWC for right price
Comes with spare fibreglass bonnet, extra pair of original tailights, steering box, wiper motor, cluster gauge, box of extra trims and badges. Brand new Super pro bushes to change every single bushing front/rear to urethane bushes, idler arm, pitman arm, tie rod ends inner/outer, ball joints.
This car has been done correctly and sounds awesome all the way to 7000rpm. Will suit an enthusiast and I would rather sell it to the right buyer who will look after it like I have. Test drive will be upon my discretion only. Nothing to spend, just drive and enjoy.
$11000 ono. STRICTLY NO SWAPS. No low balling. Silly offers will simply be ignored. I'm sure it will cost more time and money to build it to this spec. Scammers will be reported.
0421 676 171 - Richie
Thank you for looking
Share this post
Link to post
Share on other sites
