Ke55 Clutch Cable To Sr20De Trans
JasonKE55
You'll need to convert your clutch pedal to operate hydraulically.
I'm using a TA22 clutch master as it bolts onto existing KE55 firewall holes without major modifications (you need to drill a hole in the clutch pedal for the master cylinder plunger), but others (silvia?) may also be suitable.
Edited by Mechanical Sympathy
