JasonKE55 Posted March 8, 2016 Report Share Posted March 8, 2016 Hi fellas, I have just purchased a new master cylinder which I have made an adapter plate to bolt it to the standard booster in my 79 ke55. The question I have is how do you remove the brake master pushrod so I can make up a longer one?? I pull it out as far as I can and it stops. Do I need to remove the seal at the front of the booster? Cheers for your help Quote Link to comment Share on other sites More sharing options...
rebuilder86 Posted March 8, 2016 Report Share Posted March 8, 2016 Does the pushrod not have a thread in it for adjustment? I think they normally do. just have a good look at the end of it and see if it can be turned and undone. And before you ask, yes i am talking about the master cylinder side not the pedal side. Both normally have an adjustment. Quote Link to comment Share on other sites More sharing options...
kickn5k Posted March 8, 2016 Report Share Posted March 8, 2016 The question I have is how do you remove the brake master pushrod so I can make up a longer one?? I pull it out as far as I can and it stops. Do I need to remove the seal at the front of the booster? Cheers for your help Yep, gently pull the rubber boot/seal off and you should see a wire retaining clip. Pull the clip out(be careful as the piston may slide out too) and you're gold. 1 Quote Link to comment Share on other sites More sharing options...
JasonKE55 Posted March 8, 2016 Author Report Share Posted March 8, 2016 Cheers Quote Link to comment Share on other sites More sharing options...
