T50 Advice In Ke10
I have the option of 2 boxes... Would one box fit better than the other? They have different shifter spots?
Guess one is ae and the other must be Celica or something?
Is one better than the other? All advice would help..
Going on k series in ke10 and prefer not to bash tunnel
Ta22 is the early one which has a ke30-55 shifter position
Ae71 and ae86 is the later with a ke70 position
10 tailshafts are probably smaller spline but a 30-55 shaft will also go straight up the bum of the ta22 box
T50 really isn't that much bigger than a k50.....
The problem you're going to face though is the ke10 shifter position is even further forward than a 30/55 so regardless of weather you go ķ50 or t50 you're going to have to cut the hole back further.
Btw, that k box is actually a k40 not k50.... I know because I took that photo, someone else added the text.
Edited by Taz_Rx
