Jansku99 Posted September 18, 2016 Report Share Posted September 18, 2016 Hi. Old KE15 Diff (Is it B-series? 5,7"?) is making a lot of noise again and i'm out of diffs. Is there other diff's that will bolt straight in with original axle? I don't want to change bolt pattern for the wheels as I have rare and cool 4x110 wheels already. With a little thinking, KE2x diff should be same as KE1x, right? Plenty of those at Finland. I heard rumours of KE7x or KP61 Starlet's U-series 6" fitting in with original axle and driveshafts but as original diff is smaller, isn't it going to hit housing? U-series would be stronger and I think it would lower revs too. Thank you already! Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted September 18, 2016 Report Share Posted September 18, 2016 What exactly is noisy? It might just be an axle bearing which is relatively cheap and easy to fix. Quote Link to comment Share on other sites More sharing options...
Jansku99 Posted September 18, 2016 Author Report Share Posted September 18, 2016 When we last adjusted it my co-worker said that it will not be perfect as gears are worn. Bearings were good. This was 2 years ago. Quote Link to comment Share on other sites More sharing options...
Project Sprinter Posted September 19, 2016 Report Share Posted September 19, 2016 Hi Jan Post up in wanted for some axles and diff centre. They're reasonably available from other E10 gen cars here - but shipping is going to be expensive. Best regards Quote Link to comment Share on other sites More sharing options...
ke70dave Posted September 20, 2016 Report Share Posted September 20, 2016 If the gears are not totally destroyed you might be able to get away with lapping them, which would make them close to new. Need a proper gear shop to do this. Then just replace the bearings, set the pinion depth properly (!!!) and you should be motoring. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted September 20, 2016 Report Share Posted September 20, 2016 Lapping doesnt fix noise though ususally. Just reduces it a bit Quote Link to comment Share on other sites More sharing options...
tojo2 Posted September 20, 2016 Report Share Posted September 20, 2016 (edited) early ke20s are B , later ones are U, Did some Research some years ago and found that U heads should fit in your B housing using B (original) axels U : late ke20, ke30, ke70, AL25, kp61 Edited September 20, 2016 by tojo2 Quote Link to comment Share on other sites More sharing options...
