Toyota Ke 70 Project Advise
kevin
will it be costly..
Yes !
You list out what you think you need in the way of throttle bodies, plenums, manifolds, sensors, ECUs etc, and we will add to the list. The only way really is to buy a complete 3T-EU motor with everything on it and use all the parts. I reckon trying to gather parts and buy odd bits will be all too hard.
here in SA aftermarket ecu's are actually cheap, fitment instruction are relatively easy , you can even run the ecu using your standard points distributor and have the Ecu control fuel only, bottom end torque improved dramatically and fuel economy is way better that I'm still smiling today, all in all efi is the way to go
  • Upvote 1
