KaboomJohn111 Posted January 17, 2017 Report Share Posted January 17, 2017 Anyone know where to buy a new shifter rebuild kit for K-50 box (on KE70) Or does anyone have a new shifter rebuild kit Also Front and Rear oil seals Swapping K-40 for a K-50 (since I use freeway quite often) Just though I'd do a small amount of maintenance (Already got new filter and sump seal) One last thing Penrite 80w-90 or Castrol VMX 80? Quote Link to comment Share on other sites More sharing options...
Mechanical Sympathy Posted January 20, 2017 Report Share Posted January 20, 2017 (edited) Fitting a new front gearbox seal to a K50 will be a challenge, as the gearbox has to be deconstructed to get at it i.e. it is fitted from the inside, not under a front cover like say a T50. This makes it uneconomical for all but the most hardened Corolla nut. For the price of getting a shop to fit it, you might be better off finding one that isn't leaking, or even finding a K-T bellhousing. However www.amayama.com will have them. Edit, unless you mean engine main seals. In which case Amayama, or Repco et al. Edited January 20, 2017 by Mechanical Sympathy Quote Link to comment Share on other sites More sharing options...
Clapped out Posted January 20, 2017 Report Share Posted January 20, 2017 >penrite.... Quote Link to comment Share on other sites More sharing options...
KaboomJohn111 Posted January 20, 2017 Author Report Share Posted January 20, 2017 (edited) Fitting the replacement seal is no problem for me, The seals in it aren't leaking, But I know this box has been sitting around for some time when I got it Plus mate runs a shop in case I need some help I've just been struggling to find someone who sells them (not to mention how many times they though I was wanting main engine seals) @Clapped Out, so your saying go penrite? Also I do need to change the Plastic seat for the shifter (hence why i'm looking for a kit) it's split completely, So does amayama have that too? Edited January 20, 2017 by KaboomJohn111 Quote Link to comment Share on other sites More sharing options...
