Ke55 Charge Light Identified ?
harryrolla
Well if you still need to no ,the charge light wire is the yellow/white at alternator end.
The sence pin to alt positive (the big red one).S
The L pin to original charge light wire (yellow-white)
The i PIN TO 12V SWITCHED.
Just a note on the main alt wire to battery replace it with some thing bigger than the original ,mine fryed the wire.
