ke35senyorita Posted March 4, 2017 Report Share Posted March 4, 2017 hi rollaclub! I'm jason from Philippines, is it possible putting my 4k head on a 7k block? is it bolt on? ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ke35senyorita - 4k - 7k - sushimachinePh - variasAutomotive - Philippines Quote Link to comment Share on other sites More sharing options...
rebuilder86 Posted March 4, 2017 Report Share Posted March 4, 2017 HI jason, I'm jeremy from cebu, well , toledo. you can, just make sure you do your research for the Head gasket to use. the bore size is of course different, so of course you want to make sure you are using a 7k head gasket, but make sure it all lines up. any water passages may have slightly different holes, thats ok, as long as it passes some water through. Also, some advice about our water, don't skimp on coolant and distilled water! previous owner before me did with my owner jeep and i am now paying for it. the lime screws with everything in this engine. Quote Link to comment Share on other sites More sharing options...
kickn5k Posted March 4, 2017 Report Share Posted March 4, 2017 (edited) Nope, not a good idea. The 7k is wider and they also have two extra head bolts than a 3,4,5k. Edited March 4, 2017 by kickn5k Quote Link to comment Share on other sites More sharing options...
rebuilder86 Posted March 5, 2017 Report Share Posted March 5, 2017 u sure of that, ive seen 3k heads on a 7k block. what would they have had to do to make it work? haha 2 extra head bolts is a bit of a show stopper haha. Quote Link to comment Share on other sites More sharing options...
rebuilder86 Posted March 5, 2017 Report Share Posted March 5, 2017 ahh i see what you mean, perhaps the bloke i know with a 7k block just ignored those extra hols, theres actually 3 extra bolts in the pics i am looking at not full length torque out head bolts tho. i guess there could be some serious oil leaks without them, but no problems with internal combustion process. Also, this is the Philippines, what is a car without a good oil leak. They don't even sell oil sump plug washers anywhere in this country. Simply not available. Therefor the m,ost basic servicing, an oi change, can not be done successfully here unless you have a new car being serviced at the dealership! On my 4k i have to run a ʞ©$ɟing o ring around the thread. some geniuses use teflon thread tape on the threads!!!, which does sweet f all. Quote Link to comment Share on other sites More sharing options...
kickn5k Posted March 6, 2017 Report Share Posted March 6, 2017 (edited) ahh i see what you mean, perhaps the bloke i know with a 7k block just ignored those extra hols, theres actually 3 extra bolts in the pics i am looking at not full length torque out head bolts tho. i guess there could be some serious oil leaks without them, but no problems with internal combustion process. Also, this is the Philippines, what is a car without a good oil leak. They don't even sell oil sump plug washers anywhere in this country. Simply not available. Therefor the m,ost basic servicing, an oi change, can not be done successfully here unless you have a new car being serviced at the dealership! On my 4k i have to run a ʞ©$ɟing o ring around the thread. some geniuses use teflon thread tape on the threads!!!, which does sweet f all. Haha. He may not have stressed about the extra bolts, not even sure why they are in there to begin with, they are quite small. Here's why I didn't think it is a good idea. 1. A 7k head is most likely, going to be a 5-10 years newer than a 4k head. Less time to corrode and go soft from running or detonation. 2. Lastly the ports on the 7k head are far superior than a 4k flat top piston head(4k-u's are rare in Aus). I now understand the situation that ke35seyorita maybe in. Thanks Jeremy. Ke35seyorita as Jeremy's already said I'd grab a used 7k and 4k head gasket and check your main passages. Can't be too far out. Stu. Edited March 6, 2017 by kickn5k Quote Link to comment Share on other sites More sharing options...
ke35senyorita Posted March 7, 2017 Author Report Share Posted March 7, 2017 thanks guys! maybe ill just put the whole 7k thing on my ke haha or a 5k engine :) Quote Link to comment Share on other sites More sharing options...
joshua.mathews Posted March 11, 2017 Report Share Posted March 11, 2017 U can run any k head on a 7k block as the only difference is the 3 outer bolt holes which u can get put on But you have to work out yoir compression ratios Quote Link to comment Share on other sites More sharing options...
CorollaNut68 Posted March 27, 2017 Report Share Posted March 27, 2017 I put the head from my 1100 K on a 3K and it ran the best out of everything I've done. I think it bumps up the compression quite a bit. After a few years everything cracked...block, pistons, head. But while it was good...it was real good. Smoked tires in first and second, good burn on third, still chirping when you hit fourth. I was beating 5.0 Mustangs, A Ranchero with a 351.....it was quite surprising. Quote Link to comment Share on other sites More sharing options...
