suwan4910 Posted May 3, 2017 Report Share Posted May 3, 2017 KTS front shock absorber with FC3S brake kit, which I assembled face shocks to fit into the daily use. And brake discs to be used as a mini R53 plate size 276 × 22 mm. Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 The next item is watt link of SSWork. From Japan By the pros Normal of the undercarriage, hard coil, general coil, time it collapses - stretch It will sweep to the bend. It will cause the shaft to move its left-right side along its sweep. But Watt's link, it will keep the shaft does not move the left-right side better. In the short-term collapse, it will hardly move at all. Improved access to the curve. The disadvantages are only tight. Is very high maintenance Quote Link to comment Share on other sites More sharing options...
SloRolla Posted May 3, 2017 Report Share Posted May 3, 2017 They look great! Throw up some pics of the car they're going into! Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 The next item is a wheel with tires, I chose the SSR MK-3 wheels. Front Wheel Style 15 × 7.5J +19 Tire AD08 195 / 50R15 Rear Projection 15 × 8J -0 Tire AD08 205 / 50R15 Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 Cusco 116 473 A Pillowball Tension Rod Front Levin/Trueno AE86 Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 cusco 116 471 A cusco 116 471 B Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 Next item is a titanium twin end exhaust. 2.3 "I ordered a specially made for Toyota ke70. Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 all set Quote Link to comment Share on other sites More sharing options...
suwan4910 Posted May 3, 2017 Author Report Share Posted May 3, 2017 GT DOHC Quote Link to comment Share on other sites More sharing options...
SloRolla Posted May 3, 2017 Report Share Posted May 3, 2017 whew, going all out! Looks beautiful! Quote Link to comment Share on other sites More sharing options...
