briantutu Posted May 13, 2017 Report Share Posted May 13, 2017 Hi guys, i have a question with regards to my ke70. When i purchased my ke70, it already had a 3t motor and a t50 5 speed gearbox, the car has a locked diff and cut and shut knuckles. I was hoping to replace these 2 to there stock form. I was just wondering what type of diff will i need to get for this setup and as well as the steering arms, will stock ke70 steering arms fit? Thanks in advance for the help. Quote Link to comment Share on other sites More sharing options...
parrot Posted May 13, 2017 Report Share Posted May 13, 2017 (edited) As mentioned elsewhere, you need to know what diff you have now, quite likely already a T series. If so, replace with a t series centre, even an lsd if you like. As I said, count how many studs there are holding the centre in. You also said you have XT130 struts, which have a different bolt spacing to KE70 so the KE70 steering arms won't fit. Edited May 13, 2017 by parrot Spelling Quote Link to comment Share on other sites More sharing options...
parrot Posted May 13, 2017 Report Share Posted May 13, 2017 Actually I looked at what you sent me again. It was XT130 lower control arms, not struts. Without knowing what struts you have, it's impossible to say what steering arms you need. Is the seller on here? Probably Quote Link to comment Share on other sites More sharing options...
briantutu Posted May 13, 2017 Author Report Share Posted May 13, 2017 Thank you pete once again for your help. I actually bought a set of stock ke70 lower control arms and steering arms. I could just replace the xt130 with the ones i bought right? Quote Link to comment Share on other sites More sharing options...
parrot Posted May 13, 2017 Report Share Posted May 13, 2017 It depends on what struts you have. They may not bolt up to your steering arms. There are 2 bolts that go through the steering arms and bolt to the base of the strut. 1 Quote Link to comment Share on other sites More sharing options...
