Wombat Posted September 6, 2017 Report Share Posted September 6, 2017 I recently fitted a reconditioned head, complete with VRS kit to my 2000 1.8ltr (7A-fe) Corolla following a blown head gasket. The engine starts but forces oil out the rocker cover and/or cam seal at the timing gear end into the timing gear/belt housing (between a and b in images provided) Also, i have only 60 psi compression in cylinders 2 and 3. 1 and 4 have 180psi. What are likely causes? How do i correct these problems? Piston rings?? Please advise Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted September 6, 2017 Report Share Posted September 6, 2017 With the top cover sealing, the Toyota manual usually recommends some of their grey or black sealant to be installed in those corners by the cam ends. Cylinder pressure is very low at 60 psi but not on all cylinders...Only on one phase of the firing order. Do you have a reading from before the head was rebuilt? Why was it rebuilt? Just wondering if its rings, because if your engine builder did a good job on the head, and the valves seal then its gotta be the rings? Cam timing error might cause even lack of compression, carrying the same misalignment to each cylinder equally, so possibly eliminate that. Just double check your marks to be safe. Quote Link to comment Share on other sites More sharing options...
Wombat Posted September 6, 2017 Author Report Share Posted September 6, 2017 I blew my head gasket. Engine overheated but only for a minute. I fitted a reconditioned head. Cam timing marks are properly aligned. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 6, 2017 Report Share Posted September 6, 2017 Sounds like a head gasket problem, letting compression through between two and three.. Very odd... I wonder if they pressure tested the reco'd head. Unless the rings in two and three are destroyed and letting the compression passed into the sump, which would give you major blowby and push oil out the top cover seals... Quote Link to comment Share on other sites More sharing options...
megamannz123 Posted September 9, 2017 Report Share Posted September 9, 2017 is it possible to fit the head gasket backwards? not familiar with the engine but can be done on others and causes issues. Just a thought. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 9, 2017 Report Share Posted September 9, 2017 Nah- All four sides are completely different to each other.. Not much space between the cylinders though, just a little strip of metal. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted September 12, 2017 Report Share Posted September 12, 2017 As others have illuded to, the fact that the centre two cylinderes are very low, and the others are fine suggests that something is wrong between cytlinders 2 and 3. Unfortunately about all you can do is remove the head again and see what is up. did you check the block for flatness last time? just a straight edge will do. Quote Link to comment Share on other sites More sharing options...
KE70ph Posted September 18, 2017 Report Share Posted September 18, 2017 Try compression test on 3 and 4, (wet test procedure) pour a small amount (enough to cover the cylinder wall) of oil into the cylinder through the spark plug hole. - if adding the oil increases the compression, the piston rings and/or your cylinder bore may be worn or damaged. - if the pressure stays low, a valve may be sticking or seating improperly, or there may be a leakage past the gasket, valve oil seal. Quote Link to comment Share on other sites More sharing options...
